Author Topic: Can anybody help with an AB01?  (Read 5014 times)
Offline RMS Robert
  • Country: ie
  • I am Robert, an electrical contractor
    • RMS Electrical
« on: August 08, 2017, 11:09:21 pm »
Im looking for any info, or preferably a pdf or download, of the dis-assembly of an Airblade AB01. I need to remove an old AB01 to replace it with a new AB14. Cheers, Robert
Sparky
Re: Can anybody help with an AB01?
« Reply #1 on: August 09, 2017, 12:38:17 pm »
There are two Torx screws on the back of the front protrusion inside, where you put your hands, you undo those and the front cover comes off. From there, a simple electrical connector disconnects the supply. After that, depending who has fitted it, there should be two screws on the bottom of the back plate each side to the wall, the unit should then lift off its hanging bracket.
Does that help?
Offline RMS Robert
  • Country: ie
    • RMS Electrical
« Reply #2 on: August 09, 2017, 06:53:11 pm »
Thanks for your good advice. I had to remove four old AB01 units and replace these with AB14 units. I now have two AB01's in working order and two units fit for the breakers yard. Any offers. I am in Ireland.
Sparky
« Reply #3 on: August 09, 2017, 07:14:18 pm »
If you are able to package them up, we'd be interested. Shoot us a mail >here<.
