Author Topic: Dc25 Brush Bar Spins Intermittently  (Read 6053 times)
Offline luke71
« on: August 22, 2017, 07:54:43 pm »
Good Evening Guys,
Apologies if this has been asked 100 times before but i'm having issues with my DC25 brush bar.
I have recently purchased a new head as I thought the motor had gone, but the bar only spins for about a second or not at all with the new head attached.
I have checked both relays on both switches, swapped them over etc but the brush bar still won't spin.
Again, new head on it so hopefully isn't that.
Had the side cover off, can't see any damage to any of the wires, but been reading and found the Yolk Loom Fix, was thinking about giving this a try next.
Any other suggestions guys?
Thanks in advance,
Luke
Re: Dc25 Brush Bar Spins Intermittently
« Reply #1 on: August 22, 2017, 08:55:51 pm »
The yoke loom breaks up inside so you dont see it. Testing it with a meter while wiggling the wires will usually show you.
Failing which, reset switch.
Offline luke71
« Reply #2 on: August 23, 2017, 10:51:37 am »
The reset switch being the small one on the left hand side? Tried pressing it but didn't make a difference. Hopefully the yoke loom with sort the issue. :)
« Reply #3 on: August 23, 2017, 12:25:13 pm »
Yes, >>this<< is the reset switch.
