Author Topic: DC24-25 post filter fix  (Read 3361 times)
Offline taran57
« on: September 09, 2017, 02:50:00 AM »
Found that doing this will stop the whistling from the post filters,
Step one,
Grab a triangular file
Add another groove in the red release button like so,
The re insert and push firmly down so the red button clicks into the second grove, now it is locked in tight and the air cannot rush past the seal causing the whistle.
Hope this helps  :thumbsup:
Offline bluebumble485
Re: DC24-25 post filter fix
« Reply #1 on: September 10, 2017, 01:45:22 PM »
good tip I will try that
Offline dsam
« Reply #2 on: March 15, 2018, 07:03:15 PM »
Another way i use is to put a continuos roll of cotton wool under the rubber seal all around and this also helps seal firmly when replaced to stop the whistling noise.
