Author Topic: Does a DC14 brush head have any bearings in the brush roller ?  (Read 4536 times)
Offline Browntoa
« on: October 26, 2017, 01:13:41 pm »
First time I've worked on a DC14 , have it upside down to slide the brush roller out and found some small bearings and a couple of bits of metal
I assume they come from inside the brush roller assembly but wanted to check that they were not a red herring and were just trapped underneath it and were just vacuumed in at some point
Offline Browntoa
Re: Does a DC14 brush head have any bearings in the brush roller ?
« Reply #1 on: October 26, 2017, 01:58:13 pm »
Think I've answered my own question , there's bearing assemblies in both ends when the rod is removed I can see on YouTube . In that case does common sense dictate that I get a complete new OEM brush assembly rather than just the bearings
But it's now getting me wondering if the noise from what I thought was the motor was in fact knackered brush bearings . :whist11:
Oh well , it only cost me £1.27 off eBay in the first place so seeing I have the replacement Motor I'll replace both
Then sell it  ;)
« Reply #2 on: October 26, 2017, 04:36:37 pm »
Easier just to replace the brushroll, indeed.
Offline Browntoa
« Reply #3 on: October 26, 2017, 04:46:18 pm »
Agree , now I've taken it to bits the bearings at one end completely failed and has scored the metal shaft over half its length , no wonder it was making a racket .
Might run the motor with the rest removed to see if the noise has gone out of interest seeing I'll have to wait for the new brush assembly to arrive
« Reply #4 on: October 28, 2017, 09:49:52 pm »
yep, lob a new brushroll in. If it's knackered enough to shred the bearing, it'll be well worn! What's the clutch like?
Sure Stuart will do you a happy price on a brushroll and refurbished clutch!
Offline Browntoa
« Reply #5 on: November 06, 2017, 07:14:44 am »
Clutch was fine in the end , brush roll went on and nice and quiet now.
Ended up virtually rebuilding it , needed a new motor , the brush roller and a mains lead as it was badly damaged and repaired with tape.
Gave it a thorough cleaning , new filters and it's working a treat.
Now to start on the 2 DC07's I picked up for £10 the pair at the weekend.
