Author Topic: Dyson DC40 Brush Switch Problem  (Read 3604 times)
Offline johnbg
« on: November 11, 2017, 05:05:38 PM »
Dyson DC40:
Dyson DC40 vacuum with no brush action, we have now got the brush working. But now the brush switch is not working as the spring nylon lever dropped out. I have spent days trying to assemble the switch without success.
Please can you help? Thank you in advance.
Offline theheadschoice
Re: Dyson DC40 Brush Switch Problem
« Reply #2 on: December 07, 2017, 03:48:40 AM »
I put them together by laying the machine flat on it's back, putting the switch buttons in their proper positions and then with one hand.. holding the front cover up and with two fingers pinching the buttons together, so they stay in the same place when you pop the switch cover into place.
Once you're holding the switch cover and buttons properly, place one hand behind the switches on the machine and lay the cover into place from the bottom up. Hope this helps, takes a bit of practice.
