Author Topic: DC15 Animal  (Read 2701 times)
Offline Peter the Painter
DC15 Animal
« on: November 20, 2017, 07:31:50 PM »
Hi all Dyson lovers
Can you help me, I am trying to replace the On/Off power switch. I purchased a replacement switch but the spade connectors are to wide to fit the existing connectors,although it was advertised as above the switch is identical to the roller switch control.
Can any one suggest how i can get round this problem?
Offline Stow_vacs
Re: DC15 Animal
« Reply #1 on: November 21, 2017, 12:19:02 AM »
You may be able to "stretch the spade connectors over".Just use a hook tool or mini flat head to widen up the connectors to fit the switch ones.Should be fine if you do it right.
Offline wolf
  • dyson repairer
Re: DC15 Animal
« Reply #2 on: November 21, 2017, 05:29:20 PM »
Replace the spade connectors, or get the correct switch for the job speak to them at M V  this is their site they will sort you out :reading:
wolf
Re: DC15 Animal
« Reply #3 on: November 21, 2017, 05:54:40 PM »
The "LAZY" way to do this job is to fit the correct switch.
Don't create more work, and if it ever fails in future the next owner etc will probably try to fit the correct switch - then your ears will be burning.....  ;D
Re: DC15 Animal
« Reply #4 on: November 21, 2017, 09:25:42 PM »
I'm in the stretch the spades camp! If in 14 years the switch goes again and someone puts a genuine one on they can just squeeze the crimps back!
