Author Topic: DC59 Pulsating  (Read 3437 times)
Offline nevets22002
DC59 Pulsating
« on: December 07, 2017, 10:07:22 AM »
Hi everyone,  I have a dc59 that charges ok but!
The first problem is that the brush roller does not turn, I have tried the bin assembly, extension bar and roller head all on another motor body and that was ok.
The other problem is odd in that it runs for about 5 seconds then pulsates in power. Does this even with the filter removed or replaced.
Any ideas?
Re: DC59 Pulsating
« Reply #1 on: December 07, 2017, 11:23:42 AM »
Surely that is covered by dysons warranty ?
assuming they had a 2 year ticket with them.
Offline nevets22002
Re: DC59 Pulsating
« Reply #2 on: December 07, 2017, 11:32:42 AM »
 I asked the same question, turns out they did not register the warranty as they use it around their pub, still think they should have called dyson, but I am still curious to find out what this is wrong.
Re: DC59 Pulsating
« Reply #3 on: December 07, 2017, 12:34:29 PM »
Any ideas?
That would usually be this flap jammed up with muck. Free it off and clean it. Its supposed to move freely.
Re: DC59 Pulsating
« Reply #4 on: December 07, 2017, 12:44:09 PM »
Assuming you have cleaned the terminals on the bin..........
You need to take a meter and check the power output where indicated.
If no output, replace the main body unit.
