Author Topic: DC33 wand unit won't release from old hose  (Read 4667 times)
Offline Corax
« on: December 10, 2017, 12:18:20 am »
I've a problem which the usual FTFMing, YouTube video search, and general googling has failed to help - and so found this forum and would be grateful for any help offered   ;)
The model is my mum's DC33.  The hose developed a tear, and so I've bought replacement.  The fitting appears straightforward enough.
Except - the swivel catch on the upper end housing the wand seems to be stuck.  No matter how hard I press it hard I press it the wand unit won't release from the damaged old hose.  I've tried twisting the parts around in case that makes a difference but it doesn't seem to.   :'(
I'm also pressing the bottom part of the rocker button, not the top - in case someone wonders if I'm just being a total idiot lol...  :D
The part I mean is labelled as F on the schematic:
Any help much appreciated.
Re: DC33 wand unit won't release from old hose
« Reply #1 on: December 10, 2017, 01:27:51 am »
dont you have to refit the assembly to the vac then pull the wand up, i cant remember fully now...
Offline Corax
« Reply #2 on: December 10, 2017, 04:35:10 am »
I don't think that's it - unless I'm misunderstanding somehow.
I'm trying to remove the whole wand assembly (part *C* in my post above) - from the whole hose assembly - part *D* - which I've bought a replacement for.
Offline __russ__
« Reply #3 on: December 10, 2017, 10:19:20 am »
Swivel catch H is what you want to be pressing to release the hose from the wand.
Swivel catch F is to let the wand pipe drop back down inside the hose.
Offline Corax
« Reply #4 on: December 10, 2017, 10:47:38 am »
You're absolutely right - it was part *H* on the schematic that I was referring to.  That was what I was trying to press, and which won't push in.
Unfortunately that means it's still a problem, but at least I wasn't being a total muppet.  ;D
Offline Corax
« Reply #5 on: December 10, 2017, 11:13:18 am »
I followed this short video by the way.  Unlike many such instructional videos, it's remarkably concise (1 minute long) and clear.
