Author Topic: DC24 DRAWING LIMITED EDITION  (Read 3209 times)
Offline Br1son
« on: December 19, 2017, 08:45:41 PM »
I Have got a DC24 limited edition in white and the brush bar has stopped working and i have noticed that there is no reset button on the side could i ask is the motor change the same as all other Dc24 units, does the limited edition have a reset switch or not thank you
Re: DC24 DRAWING LIMITED EDITION
« Reply #1 on: December 20, 2017, 10:34:16 AM »
dc 24 head motors are all the same changing over as far as i know, early 24's had the cut out switch on the side. (or was it later heads had the cut out switch)
There is a chance it isn't the motor at fault, the yoke cable red/white (from the axis side) can break. I have also had the 1 ohm resistor on the dc24 head power pcb blow and go open circuit.
pop a volt meter set on ac ~ 500 and measure for voltage 230v on the main body head connections, oh and ensure the head switch next to power switch is correct.
« Reply #2 on: December 21, 2017, 01:00:10 PM »
Later heads don't have the reset switch and are more prone to burn out PCBs as a result.
I'd suggest you may be into a PCB and a motor. On a drawing the easiest fix in that case is to buy a new head and use it for spares as new Drawing heads are expensive if still available.
If you have a feed as suggested above, look at the PCB, if it is burned, swap it and the motor. The job is the same on both variants.
Offline Br1son
« Reply #3 on: January 01, 2018, 09:56:29 AM »
Thank you all for the advice i have taken the head apart and yes the PCB had blown in great fashion so i have change it and the motor and it is all running again thank you
« Reply #4 on: January 01, 2018, 11:37:48 AM »
 :thumbsup:
