Author Topic: Do Your DC 50 Repairs Get Their "Lean On?"  (Read 1285 times)
Offline theheadschoice
« on: December 20, 2017, 03:00:28 AM »
Every time I've had to get into the motor of a DC50, this happens. This particular customer picked this one up already, took it home, tried to bend it forward all the way and cracked the motor bucket assembly. I replaced it and it once again, leans backward. Anybody have a fix to this? Please?  :angryman: :'(
note: I've aligned the teeth on the inside of the yoke with the lowest finger going into the lowest slot of the female gear.
Re: Do Your DC 50 Repairs Get Their "Lean On?"
« Reply #1 on: December 20, 2017, 04:06:25 AM »
Wow, not heard of this one before
Does the upper ball cover (front) sit home against the suction duct at the top of the ball?
« Reply #2 on: December 28, 2017, 01:37:59 AM »
Thank you for responding Parwaz.
No, the cover wasn't going up all the way. There was also a problem with the wire running down the left side that has the rubber grommet attached to it, I hadn't inserted it into the right place. Also, the cover wasn't all the way in it's groove. They're a little trickier then the DC41! Issues been resolved.
Next time I take one apart show the offending parts here.
« Reply #3 on: December 28, 2017, 03:52:20 AM »
Aah nice one!:thumbsup: Glad you got it sorted.
I once had a DC40 where I soldered the wiring loom, got it back together and it was all good, except the stabiliser wouldn't lock unless pushed down by foot. Had to replace it with a completely new wiring loom and the stabiliser sorted itself out. When assembling a stripped one, everything's gotta be precisely right with these new Dysons around the ball area, as they're quite complex.
Offline edbelectricalservices
« Reply #4 on: March 10, 2018, 07:41:32 PM »
Suprised you managed to get it back together at all seriously tricky
