Author Topic: Oreck XL Classic XL2205RH - Stripdown and Refurb!  (Read 3349 times)
« on: December 21, 2017, 10:27:59 PM »
I've wanted an oreck for ages! Everyone says how rubbish they are, but I've never used one. All the ones I ever see for sale are 30+, and that's too steep for a curiosity.
So, back in the summer, when I netted one for 3, and a pack of bags for 2 (which I'm sure the bloke pulled out of the machine then charged me seperatly for) I jumped at it!
Was a good day that, not done anything with the other two yet, they will feature!
It ran!
But was very, very filthy!
The first thing I did was remove the outer bag, which has seen a bag leakage or 8 in it's time I think!
That went into the washing machine, and I got on with the actual machine!
The bag holder unclips into 2 parts
Type CC bags
Re: Oreck XL Classic XL2205RH - Stripdown and Refurb!
« Reply #1 on: December 21, 2017, 10:31:20 PM »
The bottom part wasn't too bad
Time to break the handle down now
Removed the cord holder
And split it
Time to unscrew the handle
Which reveals wiring
Switch lifts out and unplugs
Carling makes rubbish lager but good switches it seems!
« Reply #2 on: December 21, 2017, 10:36:05 PM »
The mains cable had a bit clamped to it to stop it being pulled out, and the strain guide unclipped, and the mains cable could be removed
Top cord hook clips out
And we can move down a notch
The main handle also forms the suction duct, and to ease unblocking, twists apart with a locking ring
Which has a rubber seal under the lock part
top and bottom, the top releases the bag part
There is a cable clip screwed to the bag housing
Surprisingly quickly, we move down to the main unit
And turn it upside down
« Reply #3 on: December 21, 2017, 10:41:22 PM »
The spare belt was present and unused
Undoing all the screws removes the base of the unit
Which has probably seen cleaner days!
2 static edge brushes unscrew from the baseplate
The metal baseplate strip unscrews
And the rubber blade lifts out
This metal bracket forms brushroll protection bars/baseplate bracing bars, and unclips
Then all the wheels pop out with some force
Brushroll next!
« Reply #4 on: December 21, 2017, 10:49:41 PM »
The old belt wasn't too bad actually, perfectly servicable
The brushroll end caps pop off
Seem's their keyed like Kirby ones to compensate for brushroll wear
Getting nicely packed out at the rear too...
The belt spindle then unscrewed from the brushroll, which took me a few minutes to work out!
The bearings and end cap holding bars pull out
Nice re-greasable bearings
Brushroll looked a bit sorry for itself though
Onto the motor now, this cover has to be removed
« Reply #5 on: December 21, 2017, 10:58:24 PM »
Which starts to reveal the motor
The suction duct starts life from this pivoting elbow
These two wires are unplugged
And with 2 more screws the motor lifts out
More wires to remove, same clamp and locking grommit as the top handle
Furniture guard lifts off
This plastic tab is the locking mechanism to lock the machine upright
which unscrews easily
« Reply #6 on: December 21, 2017, 11:03:38 PM »
I then found this access panel for the belt on the hood
So removed it
Onto the motor now, it's a Johnston
This bit was wierd, the fan holds the suction duct on, so has to be undone to get it off
The fan, however is spaced out/held in with this metal firewall
Which comes out with a little help from Mr Tappy
Fan is in good condition
There's a felt washer between the pivot and motor
Carbon brushes next, and they did a Turbopower 1! The brass snapped upon removal on both flipping sides... Deal with that later
« Reply #7 on: December 21, 2017, 11:09:09 PM »
2 long bolts has the motor apart
Armature pulls out
But the top bearing carrier does not easily seperate from the coil, so I left it be
That's it! All apart. Everything was washed, dried, polished and ready for putting back together
Firstly, the bearings got some attention. Under the black cap is a spacer washer for the balls
Every man will tell you spaced out balls are a good thing! They got a good lashing of grease (insert greasy balls joke here... :underchair:)
Then the motor was hammered together
And the fancase end plate fitted, and bolted together
My fix for the carbon brushes is the same as the fix for the Turbopower 1! Crimp the end of the carbon brush carrier to hold the spring in!
« Reply #8 on: December 21, 2017, 11:13:09 PM »
I then tried an alternate way to re-assemble the fan, which was felt washer, metal firewall, fan, washer and nut first
Which didn't really work, as the metal firewall has to be tapped in quite far to space the fan out
So I did it properly, as it came apart and it all fitted
Time to refit it, but first, the locking tab needs refitting
Spinal cable goes back through it's locking grommit
Which is clipped into place
The motor assembly can be dropped and guided into place now
And screwed down! Bumper time
Forgot the motor cover/clamp
« Reply #9 on: December 21, 2017, 11:17:43 PM »
Brushroll now, and the bearings got a lick of grease too
The brushroll came up nearly like new! Still very VERY soft, but not filthy or sticky or black now!
Everything pushed and screwed together
And fitted to the machine, with the adjustable end caps in the 'worn' brush position, just because!
Bracing bracket refitted to the base plate
Wheels refitted
OLD belt fitted in the spare belt slot
Rubber blade and metal cover is refitted
Side brushes screwed down
« Reply #10 on: December 21, 2017, 11:20:55 PM »
Then the baseplate can be fitted and close the whole thing up
I then fitted the new belt (because why not, the old belt is more than fine as a spare!) the correct way
And closed that up
Done!
Time to start building up the handle now, bag holder is fitted to the lower pole
Cable clip fitted
Then it was fitted to the machine itself
Upper cord hook is put back together
« Reply #11 on: December 21, 2017, 11:23:51 PM »
Mains cable strain relief is slid onto the mains cable
And the top handle reassembled
And screwed onto the lower handle
The cloth bag came up beautifully after the washing machine
The bag holder is clipped together
The cloth bag slides on first, past some locating bumps
Then the bag holder snaps ontop of that
The bag bottom clips on
The spring on the fancase air duct clips into the palstic bag bottom, and stops the bag blowing around
« Reply #12 on: December 21, 2017, 11:25:01 PM »
And with a new bag fitted, she is done!
Flew out the door for 60, very happy with that, would get another one with no thought at all for the right price!
Offline Sebo Dan
« Reply #13 on: December 22, 2017, 08:59:22 PM »
As always an excellent refurb and post. Cheers.
Dan
Sebo Automatic X4 Extra Eco (Blue & Yellow - 1100 Watts), Sebo Ensign SM1 (Grey Black & Orange - 1300 Watts), Sebo Automatic X1.1 Eco (Arctic White & Grey Black- 1100 Watts), Sebo Automatic XP10 (Light Grey & Grey Black - 890 Watts), Numatic Hetty HET 160 (Pink & Black - 620 Watts) & Numatic Henry HVR 200 (Yellow & Black - 620 Watts)
« Reply #14 on: December 23, 2017, 06:18:07 PM »
Great topic.  :thumbsup:
We did a couple of those a while back and got similar money for them in auction. I was hopeful they'd fetch more actually as they aren't bad for what they are.
