Author Topic: I have a dc14 which I bought refurbed and it has bent metal rod  (Read 7662 times)
Offline Dysonboy123
« on: December 28, 2017, 09:15:04 pm »
Anything I could do to fix it? I've tried to unbend the rod to make it back to normal but I'm afraid of breaking it.
Offline wolf
  • dyson repairer
Re: I have a dc14 which I bought refurbed and it has bent metal rod
« Reply #1 on: December 29, 2017, 09:48:42 am »
Which part are you referring to, look at the tech drawing on previous discussions re dc 14 :reading:
wolf
Offline __russ__
« Reply #2 on: December 29, 2017, 11:12:23 am »
It's not clear whether you've recently bought it and it's arrived damaged?
If so, get in touch with whoever you purchased it from and ask them to send a replacement.
« Reply #3 on: December 29, 2017, 01:12:59 pm »
The only rods on a DC14 will be the wand or little metal rod inside the clutch cover won't it?
« Reply #4 on: December 29, 2017, 01:28:07 pm »
unless he means beater bar rod / shaft. i reckon it's the wand, courier probably threw it over the gate into the garden  :'(
« Reply #5 on: December 29, 2017, 02:50:02 pm »
Ah yes, forgot about that!
Offline Dysonboy123
« Reply #6 on: December 29, 2017, 04:47:26 pm »
The wheel axe. Is they any way I can unbend it without breaking it?
« Reply #7 on: December 29, 2017, 04:59:43 pm »
Of course, just vice it up and tap it straight again
« Reply #8 on: December 29, 2017, 05:43:30 pm »
They are very tough, if its still in the machine be careful as the plastic will give way before the rod will.
« Reply #9 on: December 29, 2017, 07:04:57 pm »
Why are couriers such slap heads for that they dont care about anyone's belongings? Same goes for airport luggage!! >:(
Anyway, the axle is the same as a DC07/33 etc if you have a spare?
The bent axle will be quite difficult to straighten perfectly, I'm not experienced in this as I've never really bothered to straighten any bent ones lol
« Reply #10 on: December 29, 2017, 07:10:51 pm »
it's only the minority of couriers, there was a talk in on R2 last week with jeremy vine about it. It was hilarious actually.
Offline Dysonboy123
« Reply #11 on: December 29, 2017, 10:07:25 pm »
If I left it, would it be ok to use?
Offline Dysonboy123
« Reply #12 on: December 29, 2017, 10:10:54 pm »
It still spins, but should I change it? If so, how do you do it? I do have Dyson knowledge but it isn't a lot.
« Reply #13 on: December 29, 2017, 11:21:56 pm »
prise cap of one of the wheels, remove c clip then remove wheel and washer - then pull rod out.
Sounds like vac has had a heavy drop on one or both wheels, if rod is really bad one end pull it out from that end then vice it to straighten.
TBH i would leave it be if the wheels are true and spin freely ( and there is no damage to the plastics ).
Offline Dysonboy123
« Reply #14 on: December 30, 2017, 05:56:00 pm »
I bought a replacement wheel axel, took the old one off and fitted it and it is working properly. The wheel axe which has bent was also rusty at one side. The black washers which you fit on before putting on the glamour cap is a pain in the head. BTW the dc14 I had was a dc14 blitz it with a red cyclone and  dark grey body.
