Author Topic: Hoover Convertible U1124A May 1961 - Stripdown and Refurb! (Dial-A-Matic)  (Read 8705 times)
Hola!
Occasionally, something amazing happens. Occasionally, someone will message you on facebook who has seen something that they know you cannot resist, and that is amazing at all that it's being sold on facebook. This happened last summer! Thanks Jake for this...
It was being sold from a Pub. When I got there, the bloke said they bought the pub a few months ago, and this was the only thing in the loft. Looking at the yellowing it's been there for some time, and has possibly never left the pub since new. They had it in the bar in a corner as a curio, but wanted it out of the way, so onto Facebook it went. Apparently some people had made offers, I handed over full folding without question, and headed home (which was 2 miles away, so I got there quick)
What is this machine?
IT'S A DIAL-A-MATIC!
Some grille damage, it's very VERY brittle and fragile
The metalwork is  very clean though
It's a bit faded
Let's see what the bag is like
A genuine one! With a hole in it though
The bag fill holder looks a bit peaky
The pre motor 'filter' is a bit filthy
Let's look underneath
The brush strips are flipping excellent, which is a result
Ratings plate is barely readable
I thought this brown mark was a burn mark at first, but it scraped off which is lucky!
The bloke from the pub said it didn't work very well, and I think this has something to do with it
Soon had that fixed. Isn't it beautiful! I've never had one before, they always go for silly money on ebay
I wanted to use it, but the bag was scrap, and I fancied something better than a single walled pattern paper bag, and genuine ones are quite rare and expensive. Luckily, Numatic saved the day!
The fit was a tad loose though, although the seal was good. Loosening 2 of the suction duct screws and hooking the plastic frame behind them then doing them up does the job a treat!
I found a belt that fitted OK enough
Put it next to it's American cousin
Then filmed the before video
And used it for a bit! It helped me clean a mates flat before she moved out
And generally used it for a bit, since I've never had one before! But, it's time to be refurbished came round slightly quicker, mainly because I wanted to re-inforce the grille, which could only be done from the rear, so apart it comes!
First off is the cable
This being dropped reveals the bolt that holds the upper handle on
This cover plate comes off when the bolt is removed
And the handle lifts out to reveal the connector
Connector unconnected, we can have the switch off
The mains cable terminates as so
Then, on the other side the internal wiring goes to the other side of the switch/the other side of the incoming neutral
Neutral terminal is one long nut and bolt
Switch is the usual affair (for a brit machine anyway, not sure if the americans had a different switch)
The cable pulls out of the grommit, but the grommit doesn't easily pull out of the switch plate, and being made of unobtanium, I left it alone!
The handle loom pulls out now
This metal plate forms the 'thread' for the handle bolt, and slides off the handle
Shorter!
From what I gleaned from the US facebook vacuum group, I needed to go down below now
First off is the ruddy big spring that provides the more fluid upright motion when standing the thing up
Baseplate now, held on with 2 rotating clamps
Normally you loosen them and rotate but we'll have them fully out
Baseplate hinges up now, held at the front like a Senior
The seal needs cleaning up, I did try to remove it ala Senior but it didn't come, and not fancying re-creating the seal with tigerseal, I left it
The brushroll is held in with a clamp either side, that pushes down and away from its latch
Brushroll then pulls out
Important stuff
Let's pop the brushroll end caps off
Factory fresh!
One end came apart fine, the very dry and sticky bearing fell out, happy days.
Belt spindle side however...
Mr Hammer and Mr Bearing Puller sorted him out
Brush strips out
And the brushroll is done. Time to sort the suction hose out. The end comes apart like so
The hose can then be pulled through, and the other end twists off
Back to the main machine, and we need to remove the pivots.
This spring comes off
Then the two screws holding the pivot bracket on
There's also a plastic bracket the other side which is held on with 2 screws, I forgot to get a picture of that...
Anyway, then, we need to move slightly on up and open the bag door
Then undo these two metal clips that hold it on
The bag door comes off now
We'd best remove the screws holding the bag on
Whilst we are here, the screw inside the air path releases the adjustment knob
Undoing all the other screws releases the suction duct
The diverter piece lifts out
as does a felt pad, presumably to seal it up a bit
That done, we can remove the cleanerhead. This seemed to involve lifting it up and over the body, but in reality required quite a bit of physical violence before it went, did the trick though
We can remove the front height adjusting wheels now
The axle pops out of the metal holders either side
The outer wheel slides off, revealing a circlip behind that
After that, the inner wheel slides off, and a washer
The other side does the same, and then the whole bar slides out
Height adjuster now, the holding bracket comes off
Then the knob itself
We can move to the rear wheels now
They come off fairly easily, no circlips here
There's a circlip on the recline pedal though
And splits apart
This part is done!
Time for the upper body now
The big pivot bracket can come off now
Then the motor cover can be removed
Evidence of some moisture at some point
We can see the motor now!
Looks fairly clean
There's a bracket to unscrew on one side, then the motor lifts out
With the motor out of the way, we can FINALLY remove all the screws holding the front cover in place, including the 2 brass brackets at the bottom behind the motor
Pop that to one side for now, the bracket that screws the motor down can come off, along with its rubber cap
Unplugging the wires from the supressor splits the loom, and the motor can fully drop out
We don't want the exploding supressor thank you, so off that comes
The rubber seal the other end of the motor can come off
Re: Hoover Convertible U1124A May 1961 - Stripdown and Refurb! (Dial-A-Matic)
« Reply #10 on: January 05, 2018, 10:54:45 PM »
I now attempt to take the motor apart, but not very well as I don't know what I'm doing (as usual), so didn't get it fully apart.
I started by tapping the 3 locating pins out of the rear bearing casing
Which drops that off
Cork washer
Let's undo this nut and washer
Which removes a fan
I took the belt spindle off too, but TBH got no further, and didn't want to break anything, so put it back together, for now.........
And removed the very weedy looking motor casing seals
I then removed the bag door seals, which TBH was a mistake as they took ages to seat properly, but meh, too late now
We now need to remove the upper wiring harness
« Reply #11 on: January 05, 2018, 11:12:31 PM »
For reasons I can't quite remember, I had to dismantle the handle socket end
Then feed the wire through that way
Time for that pre motor grille
The metal clip comes off and releases the metal filter
The bag full indicator is quite clever. It works on airflow. By default, it shows 'Check Bag'. The exhaust airflow from the machine blows it 'upwards' and hides the warning. When that airflow drops, it can't blow it shut anymore, and so it appears
However, buggar breaking it so it stayed attached!
The plastics haven't faded that mu...oh
And that, is that! The cable was cleaned
I laughed at the fading some more
And it was all washed dried and polished
« Reply #12 on: January 05, 2018, 11:19:09 PM »
And FINALLY, we can get on with the main reason for refurbishing this, that grille! Non destructive Plan A is to mummify it in magic tape
Then, with a new stanley blade, cut out the gaps
We'll see how that looks later, but for now, we pick up the slightly less red and fluffy pre filter grille, the wash washed alot of it away...
Which isn't a massive issue really because it has a HEPA bag now, so it can be fitted for originality
The awful bag door seals went back in
« Reply #13 on: January 05, 2018, 11:23:36 PM »
Spinal cable now, and I remember why I had to strip the end, the spade terminals were too big to fit in the hole!
I knew there would be a logical reason
The height adjuster holding bracket made an excelletn tool for pulling the locking barbs back out of the little connectors so they fitted snugly back in the socket
Marvellous
The L bracket (which I don't think I mentioned before) holds the handle in, and bolts into the top of the bag compartment
Spinal cable is routed as it should be
Motor housing seals fitted
Motor rubber fitted
Supressor NOT fitted, but we have a hole to fill
« Reply #14 on: January 05, 2018, 11:29:44 PM »
That'll do it!
Some different crimps on the end
And a much more simpler join can be created
And made safe
Cover now
Screwed in
Lower brackets in
Motor in and screwed down
Motor cover on
