Author Topic: Dyson V8 battery isn't charging.  (Read 4347 times)
Offline Pylasosby
« on: January 08, 2018, 08:32:11 AM »
Indicator flashes blue - like low battery power. When charger is on, indicator doesn't light at all.
Re: Dyson V8 battery isn't charging.
« Reply #1 on: January 08, 2018, 11:24:38 AM »
Sounds like the charger. The charger output needs to be tested with a meter before you would suspect the battery.
Offline Pylasosby
« Reply #2 on: January 09, 2018, 10:59:38 AM »
Charger is ok. Battery was dissassembled and checked. It seems, that the trouble is in the battery board. Like charge does not go to the battery.
Offline Pylasosby
« Reply #3 on: January 09, 2018, 11:04:50 AM »
Charger plug seems to be wrinkled. My thoughts - that user somehow damaged the plug, and it werent connect right to dyson. Than he checked it with meter and decided to check battery too, but somehow closed the battery (if it's possible).
« Reply #4 on: January 09, 2018, 01:36:22 PM »
Just bite the bullet - replace the battery and charger imo.
I wouldn't be happy having a machine in my home that has had the battery pack disassembled.
