Author Topic: Dyson DC 29 - noise  (Read 3499 times)
Offline macias
Dyson DC 29 - noise
« on: January 19, 2018, 10:13:00 AM »
I have a problem with my vacuum cleaner, there is a whistle, here the video:
This sound appeared after the replacement of the engine and hepa filter, any idea what can be wrong ?
Offline Browntoa
Re: Dyson DC 29 - noise
« Reply #1 on: January 19, 2018, 12:32:13 PM »
Have you fitted the rubber seals correctly on the HEPA filter
Offline macias
« Reply #2 on: January 19, 2018, 02:13:07 PM »
Hi, it is only one possibility to fit this filter
Offline Browntoa
« Reply #3 on: January 19, 2018, 05:26:02 PM »
If you take the filter out and there's no noise then it's the seals 99% of the time
Offline macias
« Reply #4 on: January 19, 2018, 06:35:42 PM »
heh yes no noise...so a new filter can be damaged?
Online Dysonboy
« Reply #5 on: January 19, 2018, 10:30:18 PM »
Sometimes when buying a new hepa filter you have to swap the seals with either your old one if non supplied, or they will supply seals, most likely you need to make sure seals are present and are sealing okay.
