Author Topic: Hoover Junior Exclusive U1034 (Dec 1977) - Stripdown and Refurb!  (Read 7134 times)
What ho everyone! Decided to give my now completed IBM Thinkpad T40 a good run tonight, and what better way than writing a thread that I need to do!
The subject of tonight's how to? Well, this thing
As usual with machines people send me to repair, it was broken
Once it was fixed, it was time to pretty it up. On the surface, it looks OK, let's see what hides beneath!
First off, time to remove the bag
Inside was a brand new genuine H1, which I forgot to give back, sorry Roger!
The bag retaining screw was in good order. Some slight corrosion to the zip, but I didn't even contemplate removing it as damage to the bag would have not been good
Removed from the bellows
Bellows and bag fill tube split
Handle now, top half off
Re: Hoover Junior Exclusive U1034 (Dec 1977) - Stripdown and Refurb!
« Reply #1 on: January 23, 2018, 08:44:03 PM »
Hoover - Who Better?
Down below now, and to remove the bottom bolt
The rubber comes off the bottom of the handle
Next off is the Release Pedal screw
and the release pedal itself
Time to look underneath, and it's 97% cleaner than most of the chod we see at this stage already!
Brushroll and belt out
Axle out
Some lovely growth on one side
« Reply #2 on: January 23, 2018, 08:48:24 PM »
One bearing came right out. The other one exploded in stubbornness
I employed a hammer to remove the shell
And fished out the wobble washers from each bearing carrier
Brushes out
Bumper off now
And up with the wiring cover
Reference shot
And the mains cable is first off, along with the cable guide
Front wheels now
« Reply #3 on: January 23, 2018, 08:53:13 PM »
Split down
The height adjuster does not come out easily, not without drilling out rivets and replacing them, which is never fun. This got left alone...
And I took the rear wheels off instead
After that the handle bail comes out
The main part is held together with the central 'bolt', which is actually held on with a circlip
Then the bush that allows the release mechanism to move comes out
Said plate lifts off
The central bolt taps out and the assembly splits in two
« Reply #4 on: January 23, 2018, 08:56:09 PM »
So what makes it an "exclusive" looks identical to every other dirt searcher.
« Reply #5 on: January 23, 2018, 08:57:49 PM »
There's a little it of wear to the central pivot, but the assembly is not sloppy, so it's fine for a good while yet!
The spring may have fallen out of the bracket already
The locking plate is held in with another rod and circlip
Split
Job done! Time to extract the innards now. Unplug the headlight wiring
The live wire connects to a little spade adapter
Switch is removed
And the motor can come out!
Empty but pretty clean!
« Reply #6 on: January 23, 2018, 09:05:17 PM »
Exclusive to a store. No idea which store (probably Co-Op or a department store), but that very fragile, thin Éxclusive' branding makes all the difference! Hoover were very good at flogging a horse back in the day!
Anyway, I think this may be Mer, a remnant of past cleaning attempts!
I had not fully planned to take the firewall out, but I removed the screws, and it just fell out, the sealent having given up a long time ago...
2 screws remove the air duct
Aha! Some filth, finally!
No idea what this is, it didn't wipe off though
The wiring protector falls out too, held in with the firewall
Belt guard and it's spring can be removed
As can the brushroll retaining springs
« Reply #7 on: January 23, 2018, 09:13:54 PM »
Cable exit grommit out
Then off with the bulb plug, and it's wires
This red blanking piece was very stuck in, so I left it alone so I did not break it
Powerplant now. Seal
3 motor casing bolts
Lifted
Innards now. Rear bearing clamp first
Bit more rust here
Carbon brush holders out
« Reply #8 on: January 23, 2018, 09:22:28 PM »
Carbon brushes are beautiful
Clamps out, the armature can come out, and the fan and belt spindle removed
More tiny rust
Getting there now, onto the headlight lens! One screw was already missing
The 2 outer ones removed and the lens comes off
Inside the reflector housing
25w max
The airflow side was a bit grubby, the seal is stuck on, no way will that come off and go back on nicely!
More polish residue
« Reply #9 on: January 23, 2018, 09:35:24 PM »
And it's apart! Screws
I washed the bag, which although looked clean made the water filthy
Rinsed
And all was washed, dried, polished, machine polished where applicable and laid out to dry!
First up was a splodge of silicone grease on the end sleeve bearing
Then grease on the fan side bearing
Bearing and spacers fitted
« Reply #10 on: January 23, 2018, 09:40:06 PM »
Fan and belt spindle spun on
Carbon holders refitted
Armature and coil dropped on
Clamp and seal fitted
Carbon wire fitted
And the casing is fitted, along with the wiring block
Now to seal the firewall back into the hood. My poundland sealant had long dried up, but I spotted this in Robert Dyas for a reasonable fiver
And with the tip cut off to leave a very small hole, was easier to use than a big mastic gun. Extra points for it being able to live under the sink easier and hopefully not dry out as quickly
Sealer also applied to the firewall for the air duct
« Reply #11 on: January 23, 2018, 09:55:09 PM »
The first of the nicely polished metalwork went on now, the belt guard
Then the wiring for the headlight
Then, once the headlight wire protective tube was sealed up, the motor can plop in
Switch fitted
Front wheels now, lubricated
And fitted
Brushroll now
Centre bar is lovely and clean now, and new bearings ready for re-assembly!
« Reply #12 on: January 23, 2018, 09:59:49 PM »
Much better!
That gunk on the firewall didnt wash off either, so I cleaned off the visible part with the wire wheel
Handle bail was reassembled now. Shame about the paint chip, but this was the ONLY bit of iffy paint, and I'd have made it worse by trying to fix it! It's patina
Rear wheels were assembled
And everything fitted back
Much better!
The wiring underneath was tidied up and screwed down
Then the bag reassembled
Starting with the VERY fiddly bellows assembly
« Reply #13 on: January 23, 2018, 10:03:52 PM »
Time to fit an inner bag now, but no paper bag for this now, it can have a non genuine Sebo bag!
Lovely!
Outer bag fitted back on, always does these plastic type bags good to have a wash, they hang better
Headlight now
Done!
Time to fit the cleaned up mains cable, and the ends of the wire were tatty, so I started afresh with them
Much tidier!
Time to pop the handle back together
Then fit the bag
« Reply #14 on: January 23, 2018, 10:08:45 PM »
And after a good few layers of wax to tidy it up, Debbie Dirtsearcher is done!
Marvellous! It was then time to box it back up and send her home, hoping she didn't have the shit kicked out of her en route. But did it survive, and is the owner happy?
Well...
I think that's a positive there!
Until next time, thanks for reading!
