Our cordless vacuum stands are now available. We built a couple up in the shop today for display and to document the build procedure for the
support topic.
Here they are:
They fit all Dyson cordless models, they also have the compatibility to suit Vax SlimVac, Vax Blade, the Shark Rocket and the Dustcare range.
As the height is adjustable, it would likely only take a couple of extra holes drilled to enable them to fit pretty much any cordless vacuum cleaner.
Here is a video overview:
Not everyone wants to, is able to or allowed to
(in rented property for example) drill their wall to hang up their Dyson. These stands are the solution to that.
Already very popular in Asian countries for a year or two, we are the first to introduce professionally manufactured flat-pack ones to the UK.
Being a flat pack item, they do require some assembly. It's not terribly complex for anyone remotely practical, and there is an instruction manual included. You'll need a Phillips screwdriver and I'd also recommend an 8mm spanner or socket which will save time over using the budget spanner included. We will shortly have an explanatory assembly topic here with step-by-step photos.
UK buyers can get them cheapest from our site here:
>>Dyson V6, V7 and V8 Vacuum Cleaner Stands<<. Make sure to select
Free Delivery when checking out and it will still come by DPD next day.
There will soon be a distributor in the USA, and when we have a link for that I'll share it here. But until then, those in the USA and elsewhere overseas can take advantage of the
Global Shipping Programme that eBay offers (which sends them almost anywhere overseas with full tracking much cheaper than we could). If you are overseas, check
>>this eBay listing<< and you should see a shipping option to your country.
We have a support topic that shows you exactly how to assemble it you can find here:
How to Assemble Your Dyson Cordless Vacuum Cleaner Stand.
Happy to answer any questions.
