Author Topic: Vax Power 1 U88-P1-B Power 1 Trash Find! Stripdown and Refurb  (Read 2302 times)
« on: February 13, 2018, 12:29:11 AM »
A while ago now, late-ish last year infact, I found an amazing, no... rare, no, old cheap horrible Vax upright next to a skip. It was hanging, soaking wet and probably didn't work because they usually burn out
So I bought it home of course!
Not a valid youtube URL
And I stupidly set myself a challenge to refurb the sodding thing in the video, and that is why I am writing this on my elderly IBM Thinkpad T40, and you are reading it!
However, I start with the filter, because if this is scrap, it's game over before it's begun...
The top twists off the bin a quarter turn
And reveals a slightly dusty filter...
And a bin full of damp crap
However, some time with a Henry later and the filter looked almost passable. Air certainly passed through it again!
There were still some clingons, but I wasn't spending any money on this if I could help it, just time
Fair enough, it's got this far, time for the main show
Cyclone off
Extension wand and crevice tool removed
Re: Vax Power 1 U88-P1-B Power 1 Trash Find! Stripdown and Refurb
« Reply #1 on: February 13, 2018, 12:36:05 AM »
Cable dropped now
Top handle unscrewed and removed
And split with some more screws removed
The wand holder screws on here
Then falls off
These various screws here hold the middle part to the bottom part
All the electrics in these are in the base, nothing goes higher than this
2 screws sit behind the suction inlet for the cyclone
Online ryevac
  • Trev - not my choice of name - i was given it....
« Reply #2 on: February 13, 2018, 01:14:02 PM »
Funny, i found a similar vax a couple of weeks ago on my travels, very similar so threw it in the back of the car. Gave it a quick pat test and passed so plugged in to reveal it was fully working.
Thought great, but then noticed all filters were missing as well as tools so in the garage for parts as i aint spending a penny on it.
« Reply #3 on: February 13, 2018, 01:19:16 PM »
Nice! I fell asleep typing it up last night... Will carry on later!
« Reply #4 on: February 13, 2018, 10:38:59 PM »
Right, time to carry on, and I've moved onto the Thinkpad X60 Tablet now as the T40 isn't running too well with Bunsenlabs Linux, might try Mint, or put it back to XP.
Anyhoo, the cap that covers the hose inlet pops off
Then, we can remove the baseplate
Except we can't, as it doesn't come off! Instead, what we do is remove the front wheels by lifting until the notched bits line up and pulling
Then we get access to the screw holding the height control knob in place
Which lifts off from the top
Then, 2 screws on the rear and the hood pivots up and lifts off
An internal hose connects from the bit we took the cap off earlier to this, which I removed before this for washing. This piece just lifts out
Then the very worn brushroll and belt come out
The brushroll splits down quite nicely, take an end cap off and tap the other side out with your favourite hammer
« Reply #5 on: February 13, 2018, 10:43:42 PM »
The innards of the brush roll end caps looks like this in order
626z bearings if anyone is reading this trying to fix a jammed brushroll!
The baseplate was FULL of compacted grit
And was still a bit wet despite me leaving it a few weeks to dry in the shed
Now to split the base from the motor housing, and pivot caps sit either side
And it all then seperates
The bit that actually adjusts the height turns until tabs align with cut-outs, and out it comes!
Rear wheels now, and the chassis is VERY thin where these roll, this machine, fair play to it has taken some abuse
« Reply #6 on: February 13, 2018, 10:47:34 PM »
Release pedal out
At last a ratings plate shot!
And we can finally get to the motor
Screws are undone
The beating heart is removed
And we can see where the mains cable comes in
The switch is screwed in here
And once the housing is unscrewed the switch itself pops out of that
Mains cable is chopped out now, and the internal wiring is free
« Reply #7 on: February 13, 2018, 10:53:56 PM »
Time to remove the mains cable from the machine. And because the bit above it is the main suction channel, it's capped off, so pop the cap up
And pull the cable out and away!
To the outside now, and the switch cover comes off
Then the bottom cord hook
Motor again now, and this is the state of the exhaust vent
A state matched by the foam sound deadening wrapped around the motor
Top mount lifted off
Then the fancase seal, which revealed yet more water
Motor ID, made by the Smiling Dragon Hidden Chipmunk Suction Motor and Novelty Condom Concern (China) Ltd
« Reply #8 on: February 13, 2018, 11:05:58 PM »
Quote from: Beko
Some of the Chinese trading names can be hilarious. I happen to have some Chinese brochures right here that I picked up.
Who wouldn't want to patronise the "Everflying Industry Co Ltd" or my favourite "Jiangsu High Hope International Group Sunshine Import and Export Corporation".
It reminds me of this Top Gear segment.
Congratulations on the tragic Vax. It looks as though it may unfortunately live again.........  :underchair:
« Reply #9 on: February 13, 2018, 11:09:10 PM »
Which looked remarkably clean and not burning out
Cyclone now, and the damp mess in the bottom of the bin got scraped out
Then I found 2 screws in the top of the cyclone
Which reveals the pitiful 'cyclonic action' duct!
The cyclone latch and it's spring pop out from the top
And it's apart! No exploded shots on this as I rushed it back together to sell it, but as usual, it was all washed, dried and polished, and as you will see, came up very well!
So, cyclone  latch
These have a hole in to let excess airflow out (George told me to stop them burning out so quickly...) so I taped that up as the air rushing through it was damn annoying!
It's hidden with the catch fitted
The air path thing can go back in now
« Reply #10 on: February 13, 2018, 11:11:03 PM »
Quote from: Beko
(Attachment Link)
I didn't realise I was so close to the mark! I didn't make that name up, someone else did, I stole it just like the chinese steal designs...
Of course the tragic vax lives, would I be typing this up now if it didn't?
« Reply #11 on: February 13, 2018, 11:15:43 PM »
Anyhow, cultural rib tickling aside, the clean* filter got refitted
The much cleaner bin is ready to go on
And it looks quite smart now!
Motor now, and the dried fancase rubber goes on
The much cleaner foam goes on
Small mount on
The exhaust vent came up well
Bottom cord hook on
Power button on
« Reply #12 on: February 13, 2018, 11:20:38 PM »
Cable and its clamp get fitted
It's cap came up VERY well considering how sand-blasted it looked before
Switch got wired up and pushed into the housing
And fitted, and the wires crimped together seamlessly
Motor gets wired up and fitted now
And screwed up forever more!
The baseplate/bottom chassis came up as well as it could, bless it
I'd fitted the release pedal here. The wheels are 80% through with life I think, but still doing their job well
Lashings of GInger Grease helped them, and they got fitted
« Reply #13 on: February 13, 2018, 11:25:00 PM »
Adjusta-ma-bob fitted
More fix-everything grease on the pivot points
And the motor housing is dropped on and screwed up
Brushroll now, the under-bearing bits go on
Then the above bearing bits
Still worn, but alot cleaner!
Then the aformentioned internal hose and suction inlet
Fitted
The belt looked a tad worn, luckily a non clutch Dyson belt was found to be an exact* fit
« Reply #14 on: February 13, 2018, 11:29:51 PM »
Hood fitted
Adjuster knob fitted
Front wheels fitted
Hose port cover fitted
And now we can move up the machine! Air path rear cover fitted
The spine and that hose entry bit all go on together and screw into each other
The cable can go on now as well
