Author Topic: DC39 Animal Poor suction and noise from motor when suction applied  (Read 5422 times)
Offline fosdyke
Hi
I have a DC39 which has recently suffered a loss of suction after working OK for some years. I have to date replaced the motor pre-filter and the hepa filter and cleaned the cyclone unit and hoses and turbo head which are all free from obstruction. There seems to be reasonable suction from the head part where it attaches to the pre-filter but little at the end of the hose when the rest is assembled. I have noticed that the is a noise from the motor when the suction is obstructed by a hand which sounds like a flap engaging or moving. This sound is repeated  when the motor  is turned off as if the 'flap' is returning to its original position. Is there a bypass valve in the motor which is being activated? I am at a loss as to the cause of the problem so any help or advice would be appreciated.
Offline dragoncurt
  • Dyson FTW !
Re: DC39 Animal Poor suction and noise from motor when suction applied
« Reply #1 on: March 02, 2018, 03:54:11 pm »
Is the DC39 the one with the flat inlet. It might be some obstruction there.
I've added a youtube link which might help you.
Offline fosdyke
« Reply #2 on: March 03, 2018, 09:29:52 am »
Thanks for this.
Yes it is one with the flat inlet and I checked this as I had an obstruction here before.  :(
Offline fosdyke
« Reply #3 on: March 11, 2018, 11:11:59 am »
PROBLEM SOLVED - Stuck motor bypass valve!
