Author Topic: Sebo X 1.1, Loose Handle Screw  (Read 3260 times)
Offline VacuumTherapy
« on: March 12, 2018, 12:21:16 PM »
Hello everyone,
I have a Sebo Automatic X 1.1. I removed the top plastic handle in order to repair the wiring, which was torn at the top.
However, I can't screw the screw back into the metal handle, as the metal plate backing has come loose and clangs about inside when I shake it. I have tried to get it into place, but no success.
My handle is the one with only one screw.
How can I dissattach  the plastic part of the handle from the metal part without damaging any of the wiring,  so that I can put the screw nut/metal plate back into place? Or is there another, simpler, method to do this?
Al help is much appreciated.
Thank you in advance.
Re: Sebo X 1.1, Loose Handle Screw
« Reply #1 on: March 12, 2018, 02:13:03 PM »
Hello again,
Have found this:
Contains information on switch removal.
Any other help/advice much appreciated.
« Reply #2 on: March 12, 2018, 06:51:26 PM »
There is a strip down topic >>here<< that covers the handle.
