Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
With photos. Find it
>here<
Click
>here<
Home
Help
Login
Register
Dyson Models
Handheld, Cordless, Stick, Wand & Robotic Dyson Vacuum Cleaners
DC35 Root Cyclone disassembly
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: DC35 Root Cyclone disassembly (Read 3363 times)
PhieusYazria
Member
Country:
Gender:
Gamer and Dyson nut
on:
March 21, 2018, 03:42:31 PM »
Tweet
Does anybody know how you would disassemble the Root Cyclone module on the DC35?
I suspect the the cyclones might be clogged and causing the cleaner to cut out....
Logged
Dyson Tech
Global Moderator
Member
Country:
Gender:
Re: DC35 Root Cyclone disassembly
Reply #1 on:
March 22, 2018, 12:34:30 PM »
The outer shroud (the honeycomb bit) is fixed with several lugs and pops off with a screwdriver. Under there and at the back of the unit are some screws that allow it to be split further.
Logged
Sebo repairs Manchester
Buy a Sebo vacuum in Manchester
theheadschoice
Member
Reply #2 on:
March 29, 2018, 12:23:07 AM »
Having the same problem, I believe there's a bad sensor telling the machine it's plugged. There's two on my bench right now with the same problem.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Dyson Models
