Author Topic: dyson turbine head  (Read 44196 times)
Offline bluebumble485
dyson turbine head
« on: May 23, 2011, 07:22:49 pm »
 :bow: hi i have a dc08 turbine head the brushes will not turn i have stripped it down
the fan inside by where the button presses in is not turning is there any way you can get into the area the rubber seal and cap seems
solid ,the other end is easy to remove to take the screws out please help  :'(
Re: dyson turbine head
« Reply #1 on: May 24, 2011, 06:41:47 pm »
The chap Vacuum Cleaner House on here knows how to fix those. I'm sure he will find this before long.
Offline Vacuum Cleaner House
  • Country: za
« Reply #2 on: May 25, 2011, 08:52:44 pm »
Hi yes I will post some pics tomorrow ,
only two things go wrong with these heads.
the fan destroys it self , easy fix simply find another stuffed floor tool with a good fan and swap.
the bushes in the bottom where the brushes sit destroy them selves. I have replaced  them with ball bearings but you have to remove the cam that the brushes sit on and then grind down the raised protion of the bar that they sit on . thats easy it is re crimping the bar so the cam has some thing to stick onto that required some skill if you want a sucsessfull job
« Reply #3 on: May 25, 2011, 08:57:06 pm »
Hi many thanks for your reply  :icon_nod:
How do you get the fan out can you give me an idea?
I cant see how does it come off? Like the other side it seems is sealed in place.
  • Country: za
« Reply #4 on: May 25, 2011, 09:11:25 pm »
I am off to my workshop now to repair one so I'll take photo's for you and hopefully post them later tonight
« Reply #5 on: May 25, 2011, 09:13:20 pm »
That's brilliant. Many thanks.
  • Country: za
« Reply #6 on: May 26, 2011, 08:55:29 pm »
Hi Mate havent had a chance to upload those photo's yet got a workshop full of dysons at the moment will try for tomorrow morn
« Reply #7 on: May 27, 2011, 04:17:14 am »
no problem
« Reply #8 on: June 03, 2011, 06:05:59 pm »
 :sleepy_man:
  • Country: za
« Reply #9 on: June 03, 2011, 07:00:23 pm »
If only the man would go to sleep....he is awake until 3am...sometimes 4am most days working...working...working...tends to wake me up when he comes to bed...he he he
Regards "The Wife" aka "The Boss (said in a mafia accent)"... ha ha ha ha ha
« Reply #10 on: June 03, 2011, 07:21:57 pm »
so does that mean i am getting the pictures or not lol
  • Country: za
« Reply #11 on: June 04, 2011, 09:38:38 pm »
here we go
once you have removed the turbine housing you will need to remove the end cap , (different colours) using a large flat screwdriver you will also need a large bearing puller with narrow ends, I will post pics of another way by just using a srewdriver but you can damage the seal snd crack the housing with ease
  • Country: za
« Reply #12 on: June 04, 2011, 09:46:01 pm »
remove the cover plate, prying it loose with a small screwdriver then simply replace the damaged fan with one from a donor turbine head.
Ps I have tried glueing them back together but they fail as they spin to fast
« Reply #13 on: June 04, 2011, 10:00:21 pm »
many thanks for the reply ,i was i no rush it will be monday before i have a go now
i am sure i willl fix it with the help of the pictures
thank you one again steve
  • Country: za
« Reply #14 on: June 04, 2011, 10:06:19 pm »
No worries , buy the way the mini turbine head has the same assembily just shorter brush shafts, they have the same fan inside , we often butcher these for the parts
