Author Topic: SV03 (V6) Cuts out when Head Motor is connected ?  (Read 3405 times)
Offline NikGrey
  • If I can't fix it, you'll need a New One :)
    • Links Repair Shop
« on: May 08, 2018, 01:46:51 PM »
Hi ALL,
I have an SV03, I have the Head Apart as the machine cuts out Once when its connected and then runs as normal.
When I disconnect the Motor it doesn't cut out so Im assuming its the Motor at fault?
Before I order a replacement I though it worth tapping into the Wisdom of this wonderful forum.
What do you think folks ?
I own and Run Links Repair Shop in Norwich. I coined the phrase 'The Dyson Doctor" in 1995 but at the time I was not able to buy the domain, I lived on Corfu where there was no internet and by the time I came back to the UK that name was used everywhere !
Re: SV03 (V6) Cuts out when Head Motor is connected ?
« Reply #1 on: May 08, 2018, 05:09:12 PM »
Perhaps, but there is a possibility the battery hasn't enough juice to run both motors at once. Do you have another battery to try first?
Offline NikGrey
    • Links Repair Shop
« Reply #2 on: May 08, 2018, 05:33:42 PM »
No, I dont have another battery - Customers tend not to bring the chargers in as you know :( I have ordered a new motor - will post back my findings.
