Author Topic: DC04 clutched and non clutched wand differences!  (Read 3913 times)
Offline jpbennett
« on: August 05, 2018, 03:19:25 PM »
I am a new member so apologies if I have not entered this question in the right manner. I did try a search but no joy.
Is there any way to tell the  difference between DC04 clutched and non clutched wands by any obvious physical differences. I need to replace my clutched wand and have been offered a replacement but the owner does not know what model it came from.
Thanks in anticipation.
Re: DC04 clutched and non clutched wand differences!
« Reply #1 on: August 05, 2018, 07:52:31 PM »
One will fit the other it just gives you some hose compatibility issues sometimes.
Non-clutched usually have green fittings on a grey wand. Occasionally pale blue.
Fittings in yellow or other colours would usually tell you its clutched. A wand in red or purple is clutched too.
Clutched have an indented ring near the end of the aluminium pole, non-clutched dont.
Offline Dysonboy
« Reply #2 on: August 12, 2018, 05:15:14 PM »
Look at the end of the wand where the hose enters, if it has a grove then its clutched, if it has a buldge its non clutched.
DC04 Spare Parts
