Author Topic: Rowenta Air Force - Stripdown and refurb  (Read 4149 times)
« on: October 02, 2018, 12:42:26 AM »
I think we are long overdue another refurb thread on a machine nobody cares about arent we! So, as everyone is in bed and I'm not feeling shattered for the first time in forever, let's see how far we get!
I got this from the car boot utterly ages ago
Not a valid youtube URL
And Amy soon had it pressed into daily service for a good year, where it was pretty fine actually, if not VERY clunky. But then I got the Beko which is better in every way, so it was time to get it cleaned up and ready for sale.
We'll take the bin and floor head off for this first bit
And undo this large screw here
Forgive the dampness, it got left out in the rain the day before!
The main handle pulls off the body, and the nut that goes with the bolt can be retrived
All the many screws that hold the shell together can come off now
Out comes the large battery
And we can start to pick apart the wiring, starting with the lower body connections
Re: Rowenta Air Force - Stripdown and refurb
« Reply #1 on: October 02, 2018, 12:49:24 AM »
I should have posted earlier that the filter got lobbed in the washing machine at some point too, here it is before (we cleaned it quite regularly as it got filthy alot)
Back to wiring, the DC jack gets unscrewed from the chassis
Which fully separates the two halves of the casing. Then the lower PCB can be removed
Then the handle grip slides out
Revealing the screw that holds the top PCB/On/off switch in place
That removes all the wiring from the top part
The slider controls are held in with this screw
« Reply #2 on: October 02, 2018, 12:55:53 AM »
Out they come
The 'Booster' (full power) LED Light lens pops out, it's not a button which people who used it thought it was!
And the top half is done! Time to move down to the motor section now!
The shell is held together at the bottom by this bracket and it's 4 screws.
Which slides out when undone
This rubber seal comes out from inside, and is what seals the brush head onto the suction path
Moar screws removed!
And the power house is revealed! (and falls out a bit too as the securing screws go removed possibly a step too early
Back down below, behind there the first thing we removed sits, this spring fell out
« Reply #3 on: October 02, 2018, 01:01:37 AM »
Then this piece here unclips from above that
This is actually the bin removal mechanism, you push down onto the spring which unlatches the top, then when you fit the bin that same spring keeps the bin tight against the top mating face.
These wires are for the powerhead motor
And simply clip up the back of the chassis. Next out is this terminal block
This plastic pad holds the bracket straight against the chassis face (I presume, seemed a tad pointless TBH)
I had to remove one more thing before getting the rest of the wiring out, the exhaust vent! This plastic cap holds the foam on
Then the outer trim piece pops out
Then, finally, the screw can be got at!
Now that the motor is fully free, we can see what it is! Ah! Dr. Johnson I presume?
« Reply #4 on: October 02, 2018, 01:05:04 AM »
The fancase seal is held on with this bracket
The rubber peels off the plastic mount
Lots of sand was present between the two layers
I spied more screws
So removed them to see what happened
Ah! a fan
It seemed rude not to remove the fan as we were here
Oh look, 2 more screws!
That had the motor stripped right off the fancase housing
« Reply #5 on: October 02, 2018, 01:11:00 AM »
Now onto the bin. Get your flaps out
The shroud lifts out of the top, the filter sits above this
Looking at this now, that filter picture I posted earlier is properly out of cannon and I'm not sure where that came from as this is the filter here too!
It would have got vacuumed off and lobbed through the washing machine with the next load of black, it's just a big chunk of foam really! Shows how bad it gets after a few weeks of use though
This clip and it's tiny conical spring holds the bottom flap in place
The flap is held in with a bar that taps through
The flap seal is glued in place so I left that and started on the floor head. The triangular head wasn't really much use bar concentrating the suction to the tip to pick up cheerio's etc, it didn't add much to the cleaning experience
I started at the top
But that didnt do much once removed
So down we go, passing this on the way
« Reply #6 on: October 02, 2018, 01:17:30 AM »
This demonstrates the final MASSIVE PITFALL of this cleaner, the sodding brushroll gets clogged with hair and you have that tiny gap to cut it all out! It was overdue I think
Whilst flipping it upside down, I worked out that the bracket we removed is for, it holds the lock part in place! This centres and locks the head and the machine so it stands up
Some screws remove the top part of the housing, and reveals the next run of wires
With all the underneath screws removed, the outer bumper comes off
As does the inner cover
Ickle belt
The two front wheels pop out
Then with many screws, the suction channel unscrews. This makes suction come out of both holes, the idea being that the front channels pick up the large debris, and the brushroll sweeps up the rest and it did work rather well I have to say, it's not a bad cleaner by any means
« Reply #7 on: October 02, 2018, 01:21:58 AM »
This part does the diverting
And pulls out of the middle
All the screws holding the clear part down are removed and up it comes
Revealing the brushroll
The neck lifts out now
The internal hose twists off the neck
Sadly, the ends of the wires were probably fitted after the wires were pushed through, so snip snip
and out the came! Out also came the brushroll
The motor is held in with 2 screws
« Reply #8 on: October 02, 2018, 01:25:37 AM »
Another Johnson
I de-haired the brushroll and removed the one end cap that would
DONE!
There was a fair amount of screws
And a fair amount of washing was done, then polishing, then it's ready to reassemble
One clean brushroll!
Brushroll motor re-fitted
Brushroll refitted
Internal hose is screwed onto the neck
« Reply #9 on: October 02, 2018, 01:30:43 AM »
And with the wiring poked through, it drops into place on the lower chassis
Brushroll housing back on
Diversion piece fitted
And the suction tube can be screwed into place
These two springs help the head unlock when pushed down with one's foot
Wheels back on
Top cover on
and the outer cover on!
I fed the terminals down into the head whilst the wires were still cut
« Reply #10 on: October 02, 2018, 01:34:49 AM »
2 small crimps later and you'd never know! (unless you took the cover off and looked obviously)
This part is done
Time to fit the now cleaned bottom flap
Sadly one of the hinge sides cracked off whilst doing this, but it glued back on OK, and TBH even with it off it was OK
Flap latch back on
The washed filter joins the inner shroud/cyclone in reassembly
And the bin is done!
Motor now! The fan assembly is built back up. No idea who thought threadlock was a good idea, it's hardly a fast spinning motor  :))
Fan on
« Reply #11 on: October 02, 2018, 01:38:50 AM »
Rubber seal fits back into the outer shell minus the sand
Retaining bracket in place
Then the top wiring is fitted, then the outer trim piece
Diffuser back in
Wiring block in
We can run the wires down
And re-assembly the bin latch mechanism
Refit the spring to the floorhead holder
Then bolt the casing back on and fit the bottom trim part/floor head latch bracket
« Reply #12 on: October 02, 2018, 01:42:03 AM »
On the top handle, the on off slider is screwed in
All the wires run and PCB's placed
Handle grip inserted
Batteries refitted
And by jolly jove it was done!
It sold fairly easily, although I only asked 20 for it, but that's not bad for what cost me 4 originally, and that we had a years use out of! And their not too bad. Their not great, but a cheap one would be a fine tool to use!
« Reply #13 on: October 02, 2018, 04:12:34 PM »
Queer looking thing aren't they? I thought it was a steamer at first glance.
Online ryevac
« Reply #14 on: October 02, 2018, 04:17:05 PM »
Yes that was my thought, them horrible steam cleaners (that last 13 months).
It is an ugly thing, but if it does the job...
