Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
With photos. Find it
>here<
Click
>here<
Home
Help
Login
Register
Hoover Vacuum Cleaners
Hoover Senior 6525E
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Hoover Senior 6525E (Read 5277 times)
Sgr1973
Member
Country:
Gender:
Hoover Senior 6525E
on:
December 17, 2018, 05:37:09 pm »
Tweet
Hi all,
I have a senior 6525E in first class condition (was!!) that seemed to blow up yesterday while in use. It was working perfectly than out of no where made a horrendous pop like bang, puff of smoke through the hood vents and a small flame for around a second before shutting down. It left a terrible smell.
Its kept in the garage and not been used frequently.
Does anyone have any ideas on what could have happened and if they think it could be fixable? I thought it sounded like the motor was away but am not very tecnically minded.
Any help would be appreciated.
Logged
Madrat
Member
Country:
Gender:
Re: Hoover Senior 6525E
Reply #1 on:
December 17, 2018, 06:18:40 pm »
I would say it could be the capacitor has gone bang, but if its stored in the garage its could have got damp and has arced somewhere.
Logged
Sgr1973
Member
Country:
Gender:
Reply #2 on:
December 17, 2018, 08:24:41 pm »
Thanks for that.
I had wondered about damp with being in the garage. I realise how old they are and parts being scarce but are these particular parts you mention readily available if that’s the fault?
Logged
Madrat
Member
Country:
Gender:
Reply #3 on:
December 17, 2018, 10:11:59 pm »
Hmm possibly, if you can find the specs off the old capacitor your best bet is RS components or ebay might have the originals. BEKO (member on this forum, not the company) or ryevac will know more.
Logged
beko1987
Member
Country:
Gender:
Let's take it apart!
Reply #4 on:
December 18, 2018, 09:10:49 am »
Yep, supressor has gone! Very common on that age, being a metal tube makes it sound 7x worse than it is!
Honestly, just remove it and join the wires together. It's not 1972 anymore, digital TV does not pick up the interference, I regularly use mine with no supressor and it affects nothing
Logged
beko1987
Member
Country:
Gender:
Reply #5 on:
December 18, 2018, 09:20:03 am »
Like this (exactly the same motor and might be the same supressor wiring as yours too)
Just join the wires. Excuse my terrible job with one too many crimps but the wires going to the supressor have a diode in which pulls out VERY easily
I sort of try to unscientifically prove the interference thing here, filmed during the height of summer, bliss!
//www.youtube.com/watch?v=r5iOdEwzmnM
This will help you get it apart if you need too, their all the same
https://manchestervacs.co.uk/DysonForum/index.php/topic,1358.0.html
Good luck sir!
Logged
Sgr1973
Member
Country:
Gender:
Reply #6 on:
April 14, 2019, 08:45:25 pm »
Thanks Beko1987. I’ve done some research and saw your video pre ‘explosion’.
I thought that sounded like my experience.
I will now take apart and try and follow your fix.
Thanks for the detailed reply. The hoover is in great condition and I don’t want to lose it.
Logged
Sgr1973
Member
Country:
Gender:
Reply #7 on:
May 27, 2019, 05:40:53 pm »
Hi
Finally got round to opening the hood and this is what I found.
Just looking for some clarification that it is the suppressor and that no one can see anything else more sinister.
Many thanks for all your feedback
Logged
Sgr1973
Member
Country:
Gender:
Reply #8 on:
May 27, 2019, 05:47:30 pm »
Pictures, forgot to attach
Logged
beko1987
Member
Country:
Gender:
Reply #9 on:
May 27, 2019, 09:35:55 pm »
Yep, that's the supressor! Having done its deed and prolapsed everywhere!
Literally just join the same colour wires together either side using crimps, solder or spit and hope and job's a good-un! Just put the screw back in the top bearing housing (or remove the other 3 and give it a smear of grease then refit!
By the time you've got to that stage, whip out the 4 screws holding the motor to the chassis, then lift the motor and itll flip over to the side upside down wired up, pair of grips snugly on the belt spindle but mind it doesn't slip and chew it up, hold the fan and twist the grips, remove the belt spindle, fan, all the spacer washers and the little metal spacer and flood much 3 in 1 oil at the fancase bearing. Always tunes them up a treat!
Logged
Print
Pages: [
1
Go Up
« previous
next »
Hoover Senior 6525E
