Author Topic: DC05 Absolute plus problem  (Read 2808 times)
Offline Harris555
« on: February 04, 2019, 10:48:55 pm »
Hi
I changed my motor to a new YDK motor as the old one burnt out. I changed the plug to a new plug. It's still not working.
The only problem now is the push button. Should I order a new one and fit it. As the vaccum isn't working at all now and the push button goes up and down like normal.
Re: DC05 Absolute plus problem
« Reply #1 on: February 05, 2019, 12:41:03 pm »
Have you checked the cable?
Offline Harris555
« Reply #2 on: February 05, 2019, 12:49:43 pm »
The cable rewind doesn't work properly it comes back to a certain level and stops.what do I need to check on the wire cable.
« Reply #3 on: February 05, 2019, 12:51:30 pm »
They are prone to braking, if you can connect a cable directly to the new motor and see if it works.
