Author Topic: Dyson DC02 Breakthrough (Antarctica Solo) - Stripdown and Refurbishment!  (Read 10659 times)
I got asked to refurbish a fair few machines for a good friend of mine last year, and am finally getting round to writing them up! This one is a fairly rare DC02, the white special edition Breakthrough one, goes with a matching DC01 they did at the time!
It was FILTHY!
But very complete!ila_rendered
First up is the floor tool
Which was nice*
The front wheels are removed, revealing a nice self cleaning pad for the wheels...
The whole baseplate is held in with 4 screws and 2 hefty clips
The brush strip is removed
As is the lint picker
All this came off the brushes
The top vanity cover pops off
Re: Dyson DC02 Breakthrough (Antarctica Solo) - Stripdown and Refurbishment!
« Reply #1 on: February 07, 2019, 09:32:58 pm »
With some hammering and levering, the rear wheels came off fairly trouble free
And the pivoting part can be separated with that removed
I rescued the felt strip from it's tomb of shyte
Onto the wands now! And with the top clip removed the bit that covers the join up can be removed
Locking button removed
This locking tab then needs to be prised up a bit
And the wands can then be seperated
This is the part that pushes the locking pins into place, or pushes them out of place to adjust
The smaller wand half has this plastic sealing part that pulls out, it's filthy because it scrapes the inside of the wand at all times
« Reply #2 on: February 07, 2019, 09:38:01 pm »
Onto the hose now
Which easily pops apart. You can see the fading here though sadly
Time for the main machine! We can pop the top, this came waaay before the DC39/54 pop up handle! No innovation there, the innovation is here!
Although my aim was to remove the top half, I realised it was easier to pop it back down quickly and remove the tools, which are fairly mint
Tool door off
Mr Fiennes signature (wonder if this could be forged onto a cheque?)
Right, let's try again
The top part easily unclips from the pivot now. I took the tool door release button off but I do NOT recommend you do this tbh, it was a proper brown trouser moment getting it back on!
Under the pedals was carbon dust city
« Reply #3 on: February 07, 2019, 09:41:30 pm »
The internal ducting can be unscrewed now
The main top release button comes out
To remove the hose inlet, we remove the rubber seal
And then the circlip that holds it on
The top cover comes off the hose inlet randomly, so off it came!
At this stage I usually take the rear wheels off, although one didn't want to come and I didn't want to force it
So upside down it all went
And off came the motor cover, unlike the DC05, the wheels can stay on for this bit if you are just affecting a repair to the motor/cord reel
« Reply #4 on: February 07, 2019, 09:45:51 pm »
The switch needs to be unplugged
Then we can flip the top part over and undo the two screws
Which holds the switch top on
The switch itself lifts out too
Post motor filter gasket can be removed
Not entirely sure what this little chap does, if I refresh my memory I'll explain when we stick it all back together, but out it comes for now
The front wheels come off, but not the wheel holders, as they are VERY difficult to remove from a DC02, and I didn't want to break this as it's a bit unobtanium to get parts for!
With all that top bit out of the way, we can move onto the motor and cord reel
The neutral wire with the plastic cover needs to be removed from the motor PCB
« Reply #5 on: February 07, 2019, 09:52:24 pm »
This releases the thermal cutout loom, the other side plugs into the switch that we removed earlier
Cord reel lifts out now, to replace the cable you can see the grip to remove, then the two terminals
Now I can get to it with some pliers to gently squeeze the locking tabs the other wheel can come off
And one empty motor housing
Onto the motor now, the foam sound deadening lifts off
The plastic motor mount lifts off
The rubber seal for the motor top lifts out of that
And we have An Motor!
I whipped the fan off, which needed washing
« Reply #6 on: February 07, 2019, 09:57:52 pm »
I removed the fan spacers
And had the plastic base off the motor, because that's always a grot spot!
The motor itself is actually quite small without all the other bits
We can stick a drop of oil on the fancase bearing now too!
Cyclone now! Take the lower cone out of the bin
And admire the grot
Take the seal out that seals it to the top cone
Up top, the upper cone pulls/snaps off the cyclone top
Pull (gently) the release valves out, and seperate the seal, valve and springs
« Reply #7 on: February 07, 2019, 10:04:29 pm »
The next step is to take the shroud off the cone, which again, if you don't have to, then don't! Because it's a RIGHT SOD to get clipped back in!
Everything was then washed (black water) and then polished, the filth was amazing tbh!
The usual exploded diagram
And we can launch right into putting the shroud back onto the cone
Much swearing later
I'm not performing the release valve hack (they leak alot of air on the 01 and 02, and a nice bit of tape over the holes transforms them!But then you need to be very careful not to block them up, so best left for a collection piece than a daily driver) so the valves went back together
And put to one side, as you've now got to get the top cone and shroud onto the top plate
« Reply #8 on: February 07, 2019, 10:12:24 pm »
It's a sod, because the cone is basically the same circumference as the top... it needs to clip in to the little clip you see running around the inside
Much more swearing later, it became apparent it was easier to separate the cone and shroud again, fit the shroud
Then fit the cone
Push the release valves in
Lower cone now, top seal on
Pop that into the bin
Fit the bin to the cyclone, and this bit is done!
Onto the motor now!
Screw this part to the motor (assuming you took it off in the first place, it's a bit excessive even I agree!)
« Reply #9 on: February 07, 2019, 10:16:20 pm »
The fan is much cleaner now!
Lobbed that back together
and refitted the fancase seal
Top plastic mount
The foam goes on next, and the clear plastic part comes out of the 2 slits in the foam made just for it
We'll drop the cord reel in now. The rubber coating from the brake wheel is gone, so it does not lock in place now, will need a donor reel and a cable swap in the future to cure that, but for now, having the cable retract rather than never retract is better for the owner!
Drop the motor in alongside it
Run the wires and thermal cutout as required
refit the seal for the motor housing
« Reply #10 on: February 07, 2019, 10:20:18 pm »
And refit the cover to the lower chassis
Nope, still not remembered what this is for tbh, but back it goes!
I found a date wheel under all the sludge! 1996! We can flip it the right way up now
And refit the switch and switch cover
Filter gasket
Front wheels
I found this whilst washing it, there's a little air baffle that sits in the exhaust air path!
It slots into here
Hose inlet back together
« Reply #11 on: February 07, 2019, 10:25:29 pm »
Doesn't look as silly now it's all uniformly faded
The way to get the circlip and seal and hose inlet back on is to fit the seal to the circlip (this is the same method as the DC04 Changeover Valve seal)
Then, holding the hose inlet in one hand, feed the circlip and seal around until it snaps into place
And you have this!
Main chassis release button now! Springs on
And snap it into place
Air duct now, and a very thin foam gasket needs to be fitted (you could use a smear of silicone sealant if this is too far gone)
It's another fiddly job, as it just wants to do this
And you don't want to snap the thin top piece of plastic. Eventually, with some coaxing it snaps into place
« Reply #12 on: February 07, 2019, 10:29:28 pm »
We can fit the power and cord rewind pedals now
Fit the tool door release button
Then clip the top part onto the bottom part
Pop the bin on, and close the lid
I've missed the refitting of the wheels, which is fairly easy as they just push on, stick a small smear of grease around the contacting parts to avoid it scraping about! Tool cover on
Tools fitted, lots of red washed out of the crevice tool, but not the vacuum so something tells me the tools are not original to the cleaner...
Time to re-assemble the 'Banana'
And the only casualty happened in this entire project, the circlip snapped! Easily glued though
« Reply #13 on: February 07, 2019, 10:33:04 pm »
The cuff must be a different plastic compound to the handle, as it's not faded
Time for the wands now! Plastic seal goes into the thinner wand
Locking pin and it's spring are fitted, and do hold themselves in handily
So you can fit the 2 parts together, and push the metal tab back down to lock them together
Adjuster button clips on
I then realised that I'd forgotten to fit the metal locking pin itself, which is a tad stupid, so the last 3 steps were quickly reversed...
And then I fitted it all back together and fitted the cover to the whole thing
« Reply #14 on: February 07, 2019, 10:36:17 pm »
The wand can clip to the machine again now! (the worst parking bracket design ever, a light breeze 2 miles away knocks the wand off...)
Floor tool now! The 2 parts are bought together
And the wheels and axle are fitted, with a smear of grease on the axle to stop the wheels sounding dry and worn
Brush strip clips back into the base plate
Litter picker fitted
Wheels fitted
Vanity cover fitted
I then realised I had completely forgotten to clean the cable and plug up! So did that quickly
