Author Topic: I've tried fixing the henry but it doesn't work  (Read 7513 times)
Offline Dysonboy123
« on: February 18, 2019, 09:10:56 am »
I tried the motor, which was fine. The wires on it, which is fine and the cable which is fine. What should I do?
Re: I've tried fixing the henry but it doesn't work
« Reply #1 on: February 18, 2019, 11:20:00 am »
FINE ? look fine or tested ?
Need to test cables brown / blue backwards on continuity with a meter.
Test switch / switches... speed controller pcb fitted ?
Offline Dysonboy123
« Reply #2 on: February 18, 2019, 08:57:18 pm »
I'll look it again when I get a meter. It'd be a shame to throw Henry out when these vacuums are indestructible. Do the Henry which don't have Autosave have this problem? Like the new ones they've made.
« Reply #3 on: February 18, 2019, 09:17:51 pm »
Sorry not familiar with "Autosave" whatever that is ?
Never heard of it.
Maybe someone can enlighten me ?
Offline Dysonboy123
« Reply #4 on: February 19, 2019, 09:01:25 pm »
Autosave is that feature on the Henry's when you turn it on it goes on low mode and you can press the high low rocket switch to make it powerful. Once you turn it off, the Autosave feature goes back to low as default. These Autosaves have a problem with the PCB as it is in front of the motor and the carbon dust goes on the board, shorting it out.
« Reply #5 on: February 20, 2019, 11:39:07 am »
Oh, sorry i always known it as a speed controller.
