Author Topic: DC25 switch button  (Read 5294 times)
Offline turk
DC25 switch button
« on: February 24, 2019, 04:50:56 pm »
Please see the attached photo . There is a metal piece attached that I have not seen in other photos or posts. It makes it difficult to reassemble. Does anyone have any suggestions?
Offline turk
Re: DC25 switch button
« Reply #1 on: February 24, 2019, 07:55:26 pm »
That part is Dyson ON/OFF Actuation Arm #DY-966031-01 It doesn't show up on all parts breakdowns
Offline Gerard131929
« Reply #2 on: March 28, 2019, 08:57:04 pm »
It presses the brushbar reset switch so make sure it lines up with that if its a bit bent
Offline Mr_DC25
« Reply #3 on: July 12, 2020, 06:04:23 pm »
I cannot seem to find the Actuator Arm anywhere to purchase.
Also, it is not clear to me how it fits together. Does anyone have a diagram for how the actuator arm goes in?
I am new to this, and whilst I have replaced the switches, I cant seem to get the actuator arm to go in, so have left it out. I suspect this means that if my Dyson sucks up a sock, I will not be able to reset it withouttaking it apart. >:(
« Reply #4 on: July 13, 2020, 11:43:04 am »
I can't get access to my photos on other pc, as it is in process of being updated.
Here is bekos pics from his stripdown post.
Offline Mr_DC25
« Reply #5 on: July 13, 2020, 09:43:03 pm »
Thanks Ryevac.
Alas, the Actuator Arm does not seem to be in your pictures. It is the metal actuator arm that I cannot find a home for (see the original post by Turk).
I have now found a diagram that features it on another site, but it is still not clear to me how it fits together.... Was hoping for a photo of it in situ.
It also does not seem available to buy anymore...
« Reply #6 on: July 14, 2020, 02:20:22 pm »
I didn't think the 25 had that metal piece you describe ?
Stu Mvacs / David should be able to confirm whether it has or not
Offline Mr_DC25
« Reply #7 on: July 14, 2020, 03:11:02 pm »
It certainly does have it, although perhaps not all DC25s....?
I have found a schematic on a US site that even identifies it:
https://www.partswarehouse.com/Dyson-ON-OFF-Actuation-Arm-DY-966031-01-p/dy-966031-01.htm
