Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
With photos. Find it
>here<
Click
>here<
Home
Help
Login
Register
Dyson Models
Handheld, Cordless, Stick, Wand & Robotic Dyson Vacuum Cleaners
Dyson V10 - Stripdown and Refurb!
« previous
next »
Print
Pages: [
1
2
Go Down
Author
Topic: Dyson V10 - Stripdown and Refurb! (Read 21015 times)
beko1987
Member
Country:
Gender:
Let's take it apart!
on:
March 18, 2019, 10:11:40 PM »
Tweet
It is time! Time for a poorly Dyson V10! Dyson had refused to repair it due to plaster dust (and I expect the wrong words by the owner) so it came my way! At first, I did this to it
//www.youtube.com/watch?v=gNcx812pjKo
However that turned out to not be the issue, so I had it back (pre-arranged, I did tell the owner it might not have been that, and she was fine with it. So, of course, let's strip it down!
The problem was soon found
But, we can't stop there can we... The wands started off being very promising, as both end caps unscrewed nicely
Revealing a nice wodge of fluff all around the power connectors
Screws on the other end
Revealing some nice looking clips
Logged
beko1987
Member
Country:
Gender:
Re: Dyson V10 - Stripdown and Refurb!
Reply #1 on:
March 18, 2019, 10:15:47 PM »
Let's unscrew the wiring block first
However... no matter what I did, the ends would not come out of the wand, even with the clips released. I assume it was all pressed together, and as I did not want to break it, I admitted defeat at this stage
wiped it all down and re-assembled it! Onto the floor head!
Brushroll out
Revealing the massive motor housing
The rubber blade at the back pops out, housing and all
Then the blade slides out of the housing
We can see the screws that hold the top cover on now
Logged
beko1987
Member
Country:
Gender:
Reply #2 on:
March 18, 2019, 10:23:45 PM »
The cover lifts up at the edges, but needs popping out of the centre part, luckily the plastic is quite pliable so easily done
The 3 screws at the front enable the clear* head to lift off
The brushroll motor housing lifts out here too, although I'd advise leaving it in for now as you cant remove it yet!
As first the rear wheels need to come off
Which were in good* condition
I removed the screws next that sit under the wheels and hold the pivot together
Although whilst doing that realised the whole thing slid out of the other part! So put the screws down for a sec
And took a picture of that
Back to the pivot (and this should be very familiar to anyone who'se had a modern dyson head apart before as it's identical) but the pivot pulls apart, and you can start to release the wires
Logged
beko1987
Member
Country:
Gender:
Reply #3 on:
March 18, 2019, 10:29:51 PM »
Under the ratings plate sticker sits another screw. Remove that and the housing drops back to access the wiring run
Pull the wires out, and part of the pivot/suction duct comes away, the rest is daisy-chained with the motor loom
Usual filth
Time to release the wiring. Pop the wiring plug up and out of the head
And release the terminals, and pull everything through and off the wires!
Onto the brushroll motor. Now, full disclosure time, I did break this, and had to obtain another head (luckily the v6 has an identical head so it was very cheap, infact incredibly cheap as it was free (the donor knows who he is, thank you very much!
) but, it does show how not to do it, and the motor, so I will write it all up!
First, pluck the wires out from under the rubber seal, then the whole end assembly does unclip from the motor housing fairly easily, feeding the wires back through as you pull
Which reveals the motor
Logged
beko1987
Member
Country:
Gender:
Reply #4 on:
March 18, 2019, 10:37:06 PM »
That's not where it went wrong though, this is. You see, I tried to remove the metal bar that turns the brushroll. There's a circlip that comes off (which I failed to get a good picture of...)
Then a split pin that can be removed
Now, what you don't do is try and tap the bar into the housing, as it's a proper tight press fit into the bearing and then housing, and what you actually do is push the motor off the bar, which is a problem. What then ensues is a right battle trying to pull the motor out of the housing, as it is VERY tight, and all you can do is flick it out 0.3mm at a time until...
You can see the 2 annoying seals. These 3 cogs shouldn't be on here either
They should sit in here
So I dropped them back on using a long screwdriver
Then refitted the motor. However, I had moved the bar slightly, but could not tap it back, short of smacking it too hard and snapping the bearing out of the housing. With time, you possibly could do this, and I do still have the head to try, but as it was, it would not turn (as the tolerances were not right) and it needed to go back to the owner before she smelt a rat, so another head was speedily acquired, I put this to one side
Logged
beko1987
Member
Country:
Gender:
Reply #5 on:
March 18, 2019, 10:45:53 PM »
The main bit, the machine itself!
First off, whip the battery out!. 1 screw at the back
And 2 underneath
Safety first and yadda yadda
Next, open the bin
Then remove it by pushing the tab down
Now, the lower flap probably can be removed, however V10 bins aren't exactly 99p on ebay, and knowing how brittle these can be if forced the wrong way I opted to leave it alone. There also seems to be a spring inside the hinge mechanism too
It's fine anyway, will wash up nicely enough. The seals come out easily
Logged
beko1987
Member
Country:
Gender:
Reply #6 on:
March 18, 2019, 10:54:37 PM »
The latch mechanism seems to consist of this rotating cog, held in with a tiny screw
The other screw holds the big inner sealing ring in place, and once removed, and a screwdriver used internally to flick the ring out of it's latches
It can be withdrawn
The handle to open the bin pops off. noting the tiny spring
The (spotless) filter is removed
Revealing the 4 screws at the rear, and 2 at the back of the bin slide bit of the housing
To start to remove the wiring loom to the head, a blunt screwdriver and smack with the back of your hand pops the plug back into the machine (I did this here so one of the cyclone screw standoffs didn't snap off or something annoying like that.
And the rear half of the machine can be removed
Revealing the motor
Logged
beko1987
Member
Country:
Gender:
Reply #7 on:
March 18, 2019, 11:00:08 PM »
Well, nearly, there's a cover in the way first. 2 screws and some tabs
PCB for the thing
The blurry wire that's removed from the PCB is the data wire from the battery (runs the battery indicator LED or something I assume)
The blue wire for the speed control, live and neutral from the battery are removed, then the whole motor assembly slides out of the machine
the motor then slides out of it's housing
Then finally the black sponge (diffuser?) from the back of the motor
This is the motor. I didn't prod it too much as I imagine it's quite an expensive and annoying thing to find...
So have some pics instead! Back to the housing, the speed control slider pops out with a flick from a fingernail on one side
Logged
beko1987
Member
Country:
Gender:
Reply #8 on:
March 18, 2019, 11:11:25 PM »
Then the little circuit board slides out of the housing, rubber seal and all
Next up is the housing that brings the cables up from the battery to the motor (I forgot to say, bend the ends of the mains cables flat to really help removal of the motor, and this bit!). Using a flexible screwdriver, remove the 2 screws
Then feed the wires out, minding not to rip the tiny data wire
Flipping the thing over, and just like the V6, one screw holds the whole shebang in
Allowing for easy removal
Empty!
Onto the cyclone arrangement now
Logged
beko1987
Member
Country:
Gender:
Reply #9 on:
March 18, 2019, 11:16:15 PM »
Removing this one screw removes the bin slide which makes it alot easier to work with
And the first 4 screws can be removed from the central cone
Which lifts off
Revealing lots of stuck dust
The rubber seal lifts off
Next up is the shroud.
Remove the 4 screws, then pop it out of place by the suction inlet
Then slide it off
The bin emptying mechanism might clean the outside of the shroud off, but like every good Dyson it doesnt touch the inside
Logged
beko1987
Member
Country:
Gender:
Reply #10 on:
March 18, 2019, 11:20:14 PM »
Now, we can see more screws
Which splits the cyclone
To remove the wires, push the small plug out
Open it up and remove the terminals
And it can be fully withdrawn
The inner filth can be seen. I'm sure in the older Dysons the fine dust in the inner cone just fell out into the bin alot more?
The 4 inner cones lift out
And all the foam seals pull carefully off
And it's apart! A nice pile for washing
Logged
beko1987
Member
Country:
Gender:
Reply #11 on:
March 18, 2019, 11:23:59 PM »
A pile not for washing
I used my screwdriver set usually reserved for Thinkpad tinkering for this, the screws are TINY, again just like all the other modern ones
And the screws themselves
Everything was washed, dried and polished
And reassembled! Starting by putting the foam seals back on the cones
The middle 4 cones were slid back in (make sure the slots at the back are properly aligned)
Clean!
Logged
beko1987
Member
Country:
Gender:
Reply #12 on:
March 18, 2019, 11:31:22 PM »
Best start wiring it up again!
But this time, we can start from the front and wire the main body - to - wand plug up and fit it back in
Rubber seal on
Shroud next, and I've tried to show it, but again slots have to line up for it to refit properly
Then *click*
The 2 halves can be bought together now
As can the parts of the cyclone assembly
Which is looking much cleaner
Then screw it all together! Long screws at the top for the cyclone, shorter ones for the cone to shroud
Logged
beko1987
Member
Country:
Gender:
Reply #13 on:
March 18, 2019, 11:36:04 PM »
Onto the bin now, and the red release latch needs fitting. The spring is actually very easy, as it's not under alot of tension, so fit the spring to the red bit, then offer the red lever up to the bin, hooking the spring over it's holder as you go, then clip the other side on
Check it bounces with movement
Clip the top seal back on
Screw the bin slide back onto the cyclone
And I fitted the seals to the bin flap, then the bin to the cyclone
It's surprisingly hard to operate the bin emptying mechanism like this, without the handle to hold! Anyway, onto electrical matters, refitting the trigger and cables
Feed the wires through as you go
Then screw it down (yes you will drop the screw about 17 times trying to get it to go in if it's not a magnetic driver...)
Fit the wiring duct and screw it back down
Logged
beko1987
Member
Country:
Gender:
Reply #14 on:
March 18, 2019, 11:40:43 PM »
Fit the speed adjustment PCB
And clip the slider down. It works by magic, so doesn't need to line up with anything on the PCB, it just 'knows'
Motor now
Slot it back together
And clip the speed control and battery data wire in, then screw the main voltage wires down, carefully bending the ends back to right angles as you go
Pop the motor cover on
Then screw the motor assembly to the cyclone assembly
Fit the battery and filter and check operation. All good? You should be if you followed this correctly!
By this point, my saviour had delivered, so this is the new, working motor housing as I'd had this a few days now and didn't want to get chased up, I'll fix the broken one one day and send it back to be used, so assume I didn't break anything, and that all is original and well (gosh the dyson fan boys are going to have a right old laugh at this one... Ah well, if the maount of V6's I'm repairing at the moment is anything to go by these have 3/4 years before they all start to fail then who will be laughing?)
Logged
Print
Pages: [
1
2
Go Up
« previous
next »
Dyson Models
