Author Topic: Stripping down a dc14 cyclone  (Read 3270 times)
Offline Dysonboy123
« on: April 18, 2019, 10:55:31 AM »
Is  it recommended
Re: Stripping down a dc14 cyclone
« Reply #1 on: April 18, 2019, 12:22:01 PM »
Why not ? lid off, watch the spring and plastic peg at the rear, gasket cover off and wash the rubber gasket too.
Don't get the screws mixed up as the lid uses different to the gasket cover.
Bottom comes off with a bit of muscle, just pour a little boiling water over it first so no lever tools required
Offline Dysonboy123
« Reply #2 on: April 18, 2019, 08:57:37 PM »
I've putted it all together but the lid that goes on the gasket doesn't fit it properly.
« Reply #3 on: April 18, 2019, 10:36:32 PM »
you have the gasket fitted incorrectly
Offline Dysonboy123
« Reply #4 on: April 18, 2019, 11:04:28 PM »
I've fitted correctly.
Offline Dysonboy123
« Reply #5 on: April 18, 2019, 11:05:22 PM »
Some side stick out some dont.
« Reply #6 on: April 18, 2019, 11:36:32 PM »
take it to bits and re fit correctly
I can photo one tomorrow for you if stuck
Offline Dysonboy
« Reply #7 on: April 18, 2019, 11:38:32 PM »
Is  it recommended
Definitly! It will work much better when cleaned - besides.. If we don't take it apart, how can we clean it out for refurbishment?
The gasket must not be sat quite right around the lid as Ryevac said.
Offline Dysonboy123
« Reply #8 on: April 19, 2019, 09:14:51 AM »
Yes that would fine.
Offline Dysonboy123
« Reply #9 on: April 19, 2019, 10:17:02 AM »
Can you wash the rubber gasket or not?
It's the one that sits under the washable filter.
« Reply #10 on: April 19, 2019, 02:44:37 PM »
You can wash it all! If it's a day like it is where I am where you are it'll be dry in an hour in the sun!
« Reply #11 on: April 19, 2019, 03:12:22 PM »
Looks just like the silver screws to remove, i was getting confused possibly with another vac i did t'other day
Offline Dysonboy123
« Reply #12 on: April 19, 2019, 09:47:44 PM »
I've got it all back together, but the hole which holds the bin trigger doesn't properly align with the handle. Sorry if you think this is weird.
Offline Dysonboy
« Reply #13 on: April 25, 2019, 03:44:30 PM »
They sometimes are a pain to get the bin flap release to sit right. Try disassembling the flap release rod and then re assembling. ive had this one a couple times.
