Author Topic: V6 zero volts from connectors to bin.  (Read 2051 times)
Offline TV Man
« on: April 29, 2019, 11:13:37 AM »
Hi hope some one can help.
I have a V6 Dyson, The power head has no volts at all removed bin to get access to main machine no volts at all from contacts,
Does anyone know a way to split these completely down im pretty certain its going to be a damaged or snapped wire.
The vac motor spins up as it should so I know its only to do with brush voltage missing.
I stripped a scrapper before and wrecked it getting the damn thing apart. I know you can buy main body on its own but im trying to save customer some money.
Offline TV Man
Re: V6 zero volts from connectors to bin.
« Reply #1 on: April 29, 2019, 12:34:44 PM »
Cancel the above the  zero volts is in fact 0.2 of a volt this is a switching voltage correct if no load detected,
« Reply #2 on: April 29, 2019, 10:26:55 PM »
so are you suspecting broken cable in elbow of head unit, or possibly head motor gone ?
Offline TV Man
« Reply #3 on: April 30, 2019, 03:55:35 PM »
Hi Ryevac.
To be honest after pulling what i could apart spinning up brush head motor on bench DC power supply it ran . put all back together again and it still ran. im wandering if theres a dead spot on the armature in brush motor.
Im going charge the unit and soak test it see how it goes,
This hand held really caught me out I was convinced i had no volts but after checking another good machine i realised there is a very low voltage less than a volt when no powered tools connected , this must be some sort of feedback to the micro that switches the voltage on when it sees a load.
These things are getting to clever for there own good lol.
« Reply #4 on: April 30, 2019, 05:53:22 PM »
Aye ok, the load of the head motor probably just completes a drive circuit as like an open collector circuit - that way it can also sense the current in the hand unit and shut off to prevent damage. ?
I can't even remember what the motor looks like in a head unit tbh, maybe coming to the end of it's life ?
Funny when i used to do plenty of cd / dvd drives - they used to get a dead spot on the main spindle motors, i removed the motor, sprayed with servisol and then run them on bench supply both ways upto 10 or 11vdc... always worked !
Offline TV Man
« Reply #5 on: May 02, 2019, 09:13:39 AM »
Lol we still do that with those cd motors. it either works or doesnt.
