Author Topic: DC24 PCB  (Read 1688 times)
Offline regitsac
DC24 PCB
« on: May 24, 2019, 11:11:02 PM »
Anyone got a PCB or know where to get one?
Online ryevac
Re: DC24 PCB
« Reply #1 on: May 25, 2019, 01:01:54 AM »
Stuart (admin ) will possibly have one from a scrapper i would have thought.
Offline regitsac
Re: DC24 PCB
« Reply #2 on: May 26, 2019, 02:22:42 PM »
I would like to buy it if you have one. The alternative is a complete new head
Online ryevac
Re: DC24 PCB
« Reply #3 on: May 26, 2019, 03:39:42 PM »
Tbh the head motors are crap and dont last long, the pcb rarely fails but a knackered motor will cause the 1 ohm wirewound resistor to go open circuit.
I think there is only a a bridge rectifier - an electrolytic cap, 4 discharge resistors and the 1 ohm resitor on the pcb - oh and some versions have the trip switch too.
Do you suspect yours is faulty ? or maybe you have a knackered head motor ? - what's the actual problem you have ? i ask as many other issues can cause no head operation.
Offline regitsac
Re: DC24 PCB
« Reply #4 on: May 27, 2019, 08:37:42 AM »
I have replaced the motor but the connection pin to the pcb has been poorly soldered and has detached. It looks difficult to resolder back in place without bridging the board.
The Pcb seems to be the most unengineered part of the cleaner and it’s ability to perform is reliant upon a cheap board.
My difficulty is sourcing a replacement board without going to the expense of buying a complete head.
I have already bought a new replacement head motor which is working.
Online ryevac
Re: DC24 PCB
« Reply #5 on: May 27, 2019, 04:49:37 PM »
I may have one,
does the pcb you require have the cut off switch ?
The one i have doesn't have the switch. or just upload a pic of your pcb
Offline regitsac
Re: DC24 PCB
« Reply #6 on: May 27, 2019, 07:10:45 PM »
Hi
The one I have has the cut off switch. Does it matter?
Online ryevac
Re: DC24 PCB
« Reply #7 on: May 27, 2019, 10:02:12 PM »
I cannot remember now, possibly not - i think you can fit a switchless one and blank the hole
I will have a dig in the workshop tommorow to reveal the one i have
Offline regitsac
Re: DC24 PCB
« Reply #8 on: May 27, 2019, 10:30:41 PM »
Many thanks
Online ryevac
Re: DC24 PCB
« Reply #9 on: May 31, 2019, 12:33:08 AM »
pm sent
Re: DC24 PCB
« Reply #10 on: June 01, 2019, 02:00:38 AM »
We use all ours on our own machines.
