Author Topic: DC40 Brush Bar Not Working. How can I test the brush bar motor?  (Read 7053 times)
Offline kwells123
I have 2 x DC40s both with brush bar motor not working :(
What can I do to work out what's wrong, as I dont want to spend out on new motors if they are not really needed.
Thanks in advance :)
Offline Tim100
Re: DC40 Brush Bar Not Working. How can I test the brush bar motor?
« Reply #1 on: June 12, 2019, 07:22:12 pm »
If u put a meter over the the contacts you should get a reading there is a cable in the ball that is very common to go
« Reply #2 on: June 12, 2019, 08:39:29 pm »
As Tim says above... voltmeter on dc, look for 320vdc on the connector in the pics in the post, if volts there then replace head motor.
If no volts there in the down vaccing position then prob yoke cable broken o/c.
I did a thread on it here...
https://manchestervacs.co.uk/DysonForum/index.php/topic,3685.0.html
