Author Topic: Dc07 Cyclone - Small Repair  (Read 1507 times)
Offline rozel
« on: June 20, 2019, 11:04:40 PM »
Hi
Brilliant forum - tons of inormation thanks.  In removing the cyclone handle to clean it, I damaged one of the screw fixings.  Please see photo.
Will superglue fix this? I am not sure if it will be strong enough and might break again when I tighten the Torx Screw.  Any thoughts please?
Re: Dc07 Cyclone - Small Repair
« Reply #1 on: June 20, 2019, 11:49:16 PM »
superglue it back in place but ensure it is 100% clean where the glue joint is.
clean it with some light solvent first isopropyl etc, you can also bolster it after with a little araldite or similar epoxy.
When refitting the torx screw, heat it gently with a cigarette lighter first (not red hot !) but just enough for the screw to worm into the plastic softly, as it cools it will lock fine
Offline rozel
« Reply #2 on: June 20, 2019, 11:57:56 PM »
Great stuff, thanks
« Reply #3 on: June 21, 2019, 12:06:05 AM »
We put one slightly longer screw in if that happens.
Offline Tim100
« Reply #4 on: June 21, 2019, 04:21:16 PM »
We use plastic weld if it is the right sort of plastic will set as strong as new
« Reply #5 on: June 23, 2019, 09:46:33 AM »
I've glued them back on before. Annoying when it happens isn't it!
Offline bluebumble485
« Reply #6 on: June 23, 2019, 10:22:44 AM »
I do the same as mv little super glue then longer screw job done
