Author Topic: DC07 Chassis Question  (Read 2207 times)
Offline Dysonboy123
« on: August 04, 2019, 05:12:36 PM »
Can I wash the chassis? And if so, how long do I keep it soaked in the bath?
Re: DC07 Chassis Question
« Reply #1 on: August 05, 2019, 04:50:48 PM »
Yes. As long as you like.
Offline bluebumble485
« Reply #2 on: August 05, 2019, 10:15:07 PM »
I gwt the feeling that one is winding us up
Offline Dysonboy
« Reply #3 on: August 20, 2019, 02:15:45 AM »
within reason, EVERY part of a DC07 is washable except the electricals etc.
Everything plastic can be washed, best not to wash the metal rods within the brushroll or the wheel axel though, the wand/handle will be fine. Bearings are also a big no-no so remove them if you are going to bath the brush.
Power cable, switch, motor etc obviously cannot be washed.
Wand/handle, hose all give a good soak.
Offline Dysonboy123
« Reply #4 on: September 18, 2019, 10:48:34 PM »
Do the side break or no?
« Reply #5 on: September 19, 2019, 09:23:50 PM »
Can you re-phrase the question?
« Reply #6 on: September 20, 2019, 10:32:02 AM »
I've seen them broken on all ages, be it due to brittle plastics or just being smashed.
Offline Dysonboy123
« Reply #7 on: September 22, 2019, 10:12:17 AM »
Any help?
« Reply #8 on: September 24, 2019, 09:15:06 PM »
nothing wrong with it just carry on.
Offline Dysonboy123
« Reply #9 on: September 24, 2019, 10:12:47 PM »
I made a dent in the bit which are circled. I was wondering if it's okay to use.
« Reply #10 on: September 24, 2019, 11:33:37 PM »
Offline Dysonboy123
« Reply #11 on: September 25, 2019, 08:49:28 AM »
It's still useable, right?
« Reply #12 on: September 27, 2019, 01:08:58 AM »
Your questions are a little inane. If you don't grasp very basic science/physics, you probably shouldn't be taking stuff that connects to the mains apart.
