Author Topic: Dyson Small Ball Allergy Vs Sebo E1 Excel  (Read 3252 times)
Offline Halcyon
« on: November 18, 2019, 03:10:46 PM »
Hello guys,
I'm probably the most undecided person in the world, I know know. I change my mind about vacuum cleaners like every month.
Anyway, we've tried quite a lot of cleaners.
We've had an older version of Small Ball but it's been given to my partner's mother cause her Dc25 died.
We have Sebo E1 Excel, no boost version. And I'm thinking about getting the new Small Ball Allergy, it's 199 plus 4 tools. I know, some of you know that I had a Ball Animal 2 but I had a go with my friend's Light Ball and I find is so much different to Ball Animal 2. It's easier to use the hose, it's smaller and a bit lighter.  And the new Small Ball is exactly the same as Light Ball.
199 plus 5 years warranty.
The Sebo that we've got is second hand it probably needs new filters. The hose also makes a whistling nose around the handle so it probably needs changing too. It's gonna come to around 70£
To my surprise my partner really likes the Sebo. I think Dyson would be better as the hair doesn't get tangled around the brush roll. With Sebo it would definitely need cleaning on both mini and big one.
Plus obviously cost of bags. Luckily they're not that expensive. Although I read that the cleaner loses suction when the bag gets around half full.
We live in a 3 storey house with laminate on one floor. But we're planning to move the house in the future so we're gonna have more carpets definitely.
We also have a Dyson V6 Absolute for some quick cleaning.
What machine do you think would be better for house with 2 cats? And I'm thinking about cleaning abilities more than reliability.
Online Parwaz7862
Re: Dyson Small Ball Allergy Vs Sebo E1 Excel
« Reply #1 on: November 19, 2019, 11:40:34 PM »
I'd go for the new Small ball at £200 they are a bargain especially with the extra tools provided. I have a Light ball and I honestly think it's basically a new DC14 because the DC14 is a kickass machine that does the job with no fuss. The noise level is also brilliant. The cleanerhead on the new Dysons are absolutely fantastic because they groom excelllently, make minimal noise and are sitable for all floors. They also have bumps on the brushbar so agitate the carpet from underneath. Get the Dyson
Offline Halcyon
« Reply #2 on: November 30, 2019, 02:49:52 PM »
So I went with Small Ball.
It definitely pick us better than older Small Ball or Sebo E1 as after vacuuming there's loads of fine dust. Great on hard floors and soo much easier to use the hose than on Ball Animal 2..
Although I'm not really sure if it keeps dust inside. I obviously empty it outside but the seal on the top of cyclone doesn't seem to be very tight.
Sometimes I can wipe fine dust from the place where it says Root cyclone technology and I'm not sure if it's static or it it escapes somehow through the seal.
The tangle free turbine is also disappointing at some levels. It's great on cat tree and bed throws but on my black carpet on stairs is rubbish. It takes few passes to clean the hair and there's still something left.
Same with sofa and chair. Upholstery tool doesn't cope with hair cause it only has one velour strip and tangle free turbine leaves plenty of hair..  :underchair:
The only thing I have in mind is getting an adapter to use a 32mm upholstery tool with two velour strips. It works great on sofas and chairs.
Online Parwaz7862
« Reply #3 on: December 01, 2019, 12:43:06 AM »
I wouldnt worry about that, basically it's a seal that has a fold in it so that when the machine is on, the seal gets tighter and the fold opens and therefore seals against the bin, but I see no reason it would even leak, the bin flap seals are what I worry about. My light ball has good seals there so it's all good
Dust isn't going to escape from that seal BTW because the vacuum is sucking air, not blowing, it's static that builds up and attracts dust from the air you're breathing because the vacuum is plastic and the cyclones spin the air very fast and it's why static occurs on the blue part of the vacuum and surrounding areas
Offline Halcyon
« Reply #4 on: January 21, 2020, 08:13:17 PM »
I got the adapter and it works beautifully now. Picks up cats' hair from furniture and carpet on stairs much much better than with provided upholstery tool or tangle free turbine. I can also use my old Hoover's mini turbo but don't need it as old upholstery tool works perfectly. The adapter's got a really tight fit.
Offline Halcyon
« Reply #5 on: April 21, 2020, 12:20:30 AM »
It's unbelievable that Dyson doesn't provide any tool to vacuum under furniture like Flat out head with this model...
Ball Animal 2 comes with additional turbine head that you can use to vacuum under furniture but the tool is not compatible with Light Ball as the fitting on this machine is slightly different.. Why have they done it is beyond my understanding.
Reviews mention its strong suction but I think that it's got an average suction tbh
What amazes me is that people don't seem to know how to use it.. My colleague bought Light Ball few months ago and she didn't actually know that you could disconnect the wand and use tools with hose.  :o So she was vacuuming her sofas with upholstery tool attached to the wand's end.
I also read reviews online and people don't seem to know how to put it together, don't know how to take filters out for cleaning, don't know that there are different settings on the cleaner head. Many complain that the instruction book is hard to understand.. Kinda feels like people complain just to complain...
I was looking for oven recommendations so had a look at https://www.which.co.uk/. They do a £1 trial so I decided to have a nosey.. Can you believe that they gave Light Ball Animal and Multifloor BESY BUYS, but Small Ball Allergy is a NO BUY..
  It’s a shame as it has good qualities, but you’ll have to either heave it across floors or compromise on cleaning power, and you shouldn’t have to. There are better
models available.
They also gave it 2 stars for carpet cleaning while straight suction Miele gets 5..  :coffee: All Sebos are also average in their tests..
I don't know who does those tests, but it doesn't seem genuine at all.
« Reply #6 on: April 23, 2020, 07:29:31 AM »
That’s the thing with reviews, they’re quite subjective and the opinion of the writer.
Also, you never know if the writer has been financially incentivised.
