Author Topic: DC59 Brush Bar - Spins but then stops  (Read 20515 times)
Offline martin.d.crowe
« on: November 23, 2019, 12:07:10 PM »
Hello,
Any advice appreciated.
The brush bar on my DC59 spins for a second then stops. It will do this on each press of the trigger. It's just the brush that stops, not the suction. i.e. works fine with nozzle attachment.
Cleaned it all out, checked no blockages and taken the brush out, made sure no hair or strands.
I've taken the clear bin off and checked and cleaned the contacts with a dry cotton but and tested it without the wand and it does the same when connected direct.
Many Thanks
Martin
Re: DC59 Brush Bar - Spins but then stops
« Reply #1 on: November 23, 2019, 03:10:21 PM »
The unit needs stripping down properly and cleaning. I think Beko did a how to video he may wish to link on the topic.
« Reply #2 on: November 23, 2019, 03:17:00 PM »
I certainly did!
If you get stuck just holler!
« Reply #3 on: November 24, 2019, 03:09:51 PM »
Thanks gents. Much appreciated. Project for next weekend then!  :thumbsup:
« Reply #4 on: November 28, 2019, 10:15:09 PM »
 :tiphat:
« Reply #5 on: December 09, 2019, 11:27:47 AM »
BINGO! Great video. Solved. The problem was EXACTLY as the video with hair / fluff behind the drive head.
Thanks again. :thumbsup: ;)
« Reply #6 on: December 09, 2019, 11:33:52 AM »
I've had 3 in this weekend with the same issues, it's nuts! I think their all getting to 'that' age, the same age that kills DC25 Brushroll motors.
A top tip I found is the actual bearing in the V6 head is the same bearing used in the Clutches! Had one with the hair burnt into the ball bearing itself so changed it out.
Offline robbiedyson
« Reply #7 on: June 08, 2021, 08:08:33 PM »
Beko thank you so much for this video - a massive help
Although, when I took mine apart, down to the motor, popped it out and everything you did - it's still not rotating freely. I can't seem to detatch the motor to allow me to remove the tread...
I've started to put it back together but this video shows what I mean...
* IMG_0147.MOV.mp4 (564.11 kB - downloaded 590 times.)
The Dyson works fine without the motorhead attached - when it is attached and you turn it on this happens
Any thoughts would be so very gratefully welcome!
Thanks so much!!!!!
