Author Topic: Sebo X1.1 intermittant cutting out  (Read 2091 times)
Offline sallysaver
« on: November 25, 2019, 10:50:17 AM »
Sadly, my trusty Sebo has developed a fault.  Although still in use, it intermittantly cuts out, not for a great length of time and then seems to right itself until of course the next time.  There are no blockages.  A new bag has been fitted and the roller brush was replaced about 2 years ago.  When the fault occurs, momentarily, the red bag full light along with the red roller brush light flashes on the vacuum, but this is the only malfunction/indication I can see.
Maybe 'she's' had enough and it's time for a replacement but any suggestions as to what could be happening would be greatly appreciated.  Thank you
Re: Sebo X1.1 intermittant cutting out
« Reply #1 on: November 25, 2019, 05:36:04 PM »
It needs to be checked over. That is quite likely to be one of the internal power boards.
If you're not local to us we offer a send in service you can read about here: Sebo Repairs. You'd only need to send the base unit and handle/flex in, the main body (with the bag in) you'd not need to send.
