Author Topic: Sebo height adjustment problem  (Read 3529 times)
Offline Seborthebest
« on: February 25, 2020, 09:19:13 PM »
I have got a Sebo X4 with a height adjustment issue. The height indicator lights up as it is going up and down but its not gripping the carpet. I have taken apart the servo motor height adjuster(thanks to a previous post). Once assembled it works for a few minutes and then stays too high. Once switched off it stay in the highest position, is this normal? Do I need to bite the bullet and buy a new servo motor or could be the PCB? Any ideas please?
Re: Sebo height adjustment problem
« Reply #1 on: February 26, 2020, 06:32:46 PM »
When it is stood up it should rise to its highest setting.
When it is reclined, is it visibly lowering?
« Reply #2 on: February 27, 2020, 07:45:06 AM »
Yes when I start using the cleaner it does lower, but is taking 6 to 7 seconds to work. When I am on a hard floor it lowers and stays lowered when I switch it off. From the lower position where it grips fine for 10 seconds, then it rasies and you lose grip, then you just get wheel marks.
« Reply #3 on: February 27, 2020, 01:19:02 PM »
I'd be inclined to try a brush roll first. How old is the machine? What wattage is it? Had it ever had a brush roll?
Is it behaving the same before and after you had the servo in bits?
« Reply #4 on: February 27, 2020, 07:55:20 PM »
I bought the machine second hand. I have had it for 3 years. I don't think that it is very old ....5 or 6 years. I have just replaced the roller. Yes still the same fault once I have reassemble. It takes an age to adjust the height, then doesn't maintain that height once it has got there. It's a 1100 watt.
« Reply #5 on: February 28, 2020, 09:14:18 AM »
Doesn't the hall effect sensor alter the height - as the friction is detected on the brush roll it raises the machine from the floor ? i would be looking at the sprocket / belt that drives the brushroll shaft / dog (bearings in this area) ?
I will Admit i don't do a lot of sebo, but just trying to think outside the box...
I think i had this issue a few years ago - one was on a brand new x4 machine which was returned to sebo, another case i had one and never got to bottom of it so dissed the servo assembly as customers budget was exceeded on the repair.
Offline Prestbury Vac Repairs
« Reply #6 on: February 28, 2020, 01:32:14 PM »
Its a Long shot but you could try resoldering the sensor I have had them dry jointed ,
« Reply #7 on: February 28, 2020, 01:47:20 PM »
Good call, could even be the sensor itself i suppose ?
« Reply #8 on: March 01, 2020, 08:15:04 PM »
Thank you. Where is the sensor on sebo? I have re soldered the little circuit board on the servo.
« Reply #9 on: March 02, 2020, 09:16:26 AM »
Its top right hand corner it has two lead outs that are bare wire, they may have small blobs of silicon on them , Try Resoldering these lead outs to the PCB.
