Author Topic: dc33 not good suction from bottom  (Read 3097 times)
Offline bluebumble485
« on: March 01, 2020, 08:43:34 PM »
hi guys  I think I am loosing plot got dc33 new motor great suction at hose taken side valve out cleaned it baby oil moves great ,will not pick up great from bottom, clutch working replaced small hose new rope seals still not strong suction on bottom ,its driving me mad never had this before any thoughts .its my age I am missing something
Re: dc33 not good suction from bottom
« Reply #1 on: March 02, 2020, 09:31:51 AM »
 onto side change over assy - is the main gasket fitted to the removeable inspection piece, and the change over assy has a rubber gasket on the underside - make sure that is still there.
I would use automotive silicone spray on moving plastics and gaskets myself, not baby oil.
Had the latter missing before on a (dc14, same as 33 07 etc) which causes that.
« Reply #2 on: March 02, 2020, 02:03:25 PM »
thanks I will look been doing refurbs 20 years now never had one like this one lol
 :thumbsup:
« Reply #3 on: March 02, 2020, 08:14:59 PM »
Must be change over assy / gasket if you are getting full suction on the wand.
« Reply #4 on: March 03, 2020, 12:12:04 AM »
Some clutches can be dodgy, they work brilliant one moment and then suddenly the brush stops grooming (check the brush doesn't stop spinning easily by placing your hand under a rug with the dyson brushbar on top)
I had a brand new Dyson clutch in one of mine. Was grooming carpets brilliant one minute, then suddenly it wasn't!
Is the issue more to do with the grooming or suction tho? Can't think of anything other than checking the pivoting head is sealed flat against the floor and that the internal hose blocked with your hand activates the suction relief valve
« Reply #5 on: March 03, 2020, 05:58:15 PM »
cheers for help I have never had one like this clutch I have checked ,got to be the side valve hope to get to it wed or thurs  will post if I sort b
« Reply #6 on: March 31, 2020, 07:22:15 PM »
finally sorted it it was one of the qt replacement hoses ,only buying genuine from now on not worth the hassle
« Reply #7 on: March 31, 2020, 10:45:15 PM »
 :thumbsup:
« Reply #8 on: March 31, 2020, 11:19:40 PM »
Nobody has got the bottom hose right yet. We use only the genuine ones.
