I have dismantled the X1 lower machine to find the commutator brushes are very worn and do not appear to contact the commutator firmly. The commutator is blackened, which to me suggests shorting across the brushes and commutator
If the commutator is blackened enough to be scored and damaged beyond repair or not, is your decision call. We only replace the brushes if the armature is in otherwise good condition. Usually by the time they're black, it's too late. But thats an individual engineer's call. Some people clean them up and claim success.
I cannot find a way of actually removing these brushes and would be grateful if anyone would advise me if this is possible or not.
We recently made a rebuild video on Sebo motors here:
That is the later motor than yours, but the job is pretty much the same.
The motor ident is an AMETEK OH44240 117818-08 12/19/97 F2. The power cables from the motor are about 15" long.
If you choose to replace the motor, that motor is
>here<If it is necessary to replace the motor because the brushes are built in what other items would I need to ensure the new motor fitted and the machine functioned correctly? The current belt number is 5379. Would I need different power cables to those currently attached to the defunct motor and would there be a need for a different rubber mounting and is there anything else I would need?
If you change the motor, the one linked above is the same - a direct replacement.
If you choose to change the belts at the same time - always good practice - they are
>here<.
If you choose to rebuild the motor, the brushes are
>here<, the bearings are
>here< and in case of need, the bearing puller is
>here<.
The decision to rebuild or replace must always the the choice of the individual engineer. It's worth considering also that motors, brushes, bearings, etc., are regarded as trade items; not retail. As such, they are sold on B2B terms, which means they are not returnable. It also means they dont carry a warranty from Sebo or us as we are unable to verify the expertise of the fitter, the surrounding components or see the usage environment.
