Author Topic: AEG DeLuxe Electronic 608 BlackLine! Full Refurbishment Journey!  (Read 1397 times)
Hi!
Way before Sebo decided to muscle in on the domestic market by painting their commercial cleaners prettier colours, before bagless, before the rise of the cheap rubbish, in the 1980's, if you wanted quality, and I mean proper quality, you went German, with either a Miele or an AEG. Yes, AEG, before they had their head chopped off by Electrolux were the mega luxury, bulletproof vacs one might have had in the 1980's for their 5 bed detached house with 3 cars on the drive...
And I picked one up for a fiver from the car boot sale!
Yes this dates how behind I am with my threads, that's my blue Laguna, the car I had 4 cars ago...
and it was alright really
With the only repair being some tape to the handle end
With good intentions I took the hose apart
Re: AEG DeLuxe Electronic 608 BlackLine! Full Refurbishment Journey!
« Reply #1 on: May 16, 2020, 12:08:52 AM »
and washed it. Then I did nothing with the cleaner... Until nearly 2 YEARS LATER! when at the SAME carboot, I found another one for a fiver!
It had all of its small tools
and seemed just overall in better condition
There wasn't anything else at the car boot I don't recall but that's fine, I was happy enough so scampered home as fast as I illegally could and got to work!
It has a different style/era of floor tool
And rusty wands
So out comes the first one from the shed
« Reply #2 on: May 16, 2020, 12:20:29 AM »
The hose end gets re-split up
And it's onto the wand
With the button removed, you can pop up the bent in metal tab and it all slides easily apart
Floortool next!
And we have an interesting repair to hold the wheels on
So we'll have all that apart
Baseplate next which thankfully was very clean
« Reply #3 on: May 16, 2020, 12:24:00 AM »
And comes off with some screws
Sadly it wasn't filled with fluff. I like them when they are like that!
Unlike other floor tools, the entire top unclips from the base
The swivel neck comes nicely apart
The retracting brushes and the metal levers that let them do this come off
And pull apart
The pedal bar can be removed now
And it seems thats the floor tool done, as the next picture is of the vacuum cleaner!
Time to pop the hood
and remove the bag which was smelling brilliant after 2 years in the shed whilst full of who knows how many years of dirt....
« Reply #4 on: May 16, 2020, 12:28:22 AM »
The bag holders are vertical posts, which spring outwards to stop the bag door closing if a bag is not fitted. We do not refit these...
2 nice sturdy tabs release the bag door
The fixed hose inlet does come out with a good tug, and the running pieces that make it swivel come out
The spring for the bag door latch sits like so
And with a bit of a fiddle the latch and front bumper come off the hood
We can remove the bag holders
and head straight on to the motor housing, which is just a few screws
The cord is still going through the machine so the cord reel comes out first
and the motor wires disconnected
« Reply #5 on: May 16, 2020, 12:32:25 AM »
The plug needs to come off next
The cord reel confirmed what I wasnt going to do anyway, flipping HATE opening cord reels, never do unless I have to...
Massive EverReady plug removed
And we can pull the flex through and call the cord reel fully removed
The actual cord reel brake is this piece of plastic with accompanying spring. I had to cabletie the cord reel together so it didn't unwind...
There is ALOT to come off this top panel, starting with the pedals
Then the bar for the cord reel (this just presses that plastic bar up allowing the cable to reel in)
The pivot points of the bag door come out too
This is the bar for the speed control
« Reply #6 on: May 16, 2020, 12:37:08 AM »
It sits in this groove here, with the spring providing the bar tension
The entire top trim comes off now, which also lets us remove the cable port cover
This must be fab in euro-land where the small plugs fully fit inside the recess, but alas in the UK they do not. It had probably never been moved before I moved it...
The bag full light lens pops out
As does this small piece of metal which stops the cord rubbing through the plastic housing as it's pulled out
This is the latch for the bag door. I can't actually remember if I did take it off but I wouldn't recommend you do, its a bit pointless...
Tools out!
And split down a bit
The tool compartment pops off it's runners
« Reply #7 on: May 16, 2020, 12:44:49 AM »
Time for wires now, and take photo's and get pulling
2 black & black/white cables go here
The bag full light would never shine brightly looking like that!
The glorious PTO socket which has never had anything plugged into it sadly
The wires go this way round
Hidden under the tool compartment, there is a removable cover! Under that cover a totally perished bit of diffuser foam fell out
I found this as I unscrewed the motor housing itself
I bet this thing ran very hot when it got going
Under the sound deadening was no better...
« Reply #8 on: May 16, 2020, 12:48:47 AM »
Onto the PCB itself now. This white part is what translates that wavy bar's movement to something the potentiometer can read
The board was quite dirty considering the machine didn't look like it has been very wet
There is a heat sensor we need to unscrew too
Then we can access the big beefy motor!
Which is held down by these massive clamps and rubber dampers. If this was a 2015 vac, these would be shitty brittle plastic and a small blob of hot glue on the end...
There was alot of MDF dust under here
The bag indicator pressure tube can come out
« Reply #9 on: May 16, 2020, 01:07:51 AM »
The furniture guard can come off now
And the pre motor filter grille. Not the front grille, the grille that separates the motor housing from the bag housing
I really wish I did not remove these as some broke, but the wheels and tyres came off
The parking slow detaches from the back of the machine with this now visible screw
The front wheel pops off
And splits into a fair few pieces
Onto the motor now, and the fancase seal comes off
ID marks
First off were the Carbon brushes
Then the bolts that hold the motor together, and the top bearing holder can be removed
« Reply #10 on: May 16, 2020, 01:12:13 AM »
The coil and mass of connected wires can be moved to one side for later cleaning
The fancase came off next, and all this fell out from just tapping the cover off
It's a dual fancase design these motors so the first fan and its spacers come off
Then a second fan chamber gets tapped off and the 2nd fan removed
Pile of bits ready for washing!
Which got washed. Then I sat down and did it ALL OVER AGAIN on the other cleaner. It must have been quite boring/not bad as I only took a picture of how grim the lint pickers looked...
The fans got a wash too and they needed it...
A few days later, with everything dry I can mask off the decals and get polishing!
« Reply #11 on: May 16, 2020, 01:15:52 AM »
Can't get much of a better 50/50 shot than with 2 full identical parts!
The floor tools only differ by one digit too, which is presumably the colour
It's really tricky to photograph in low light
Cleaned up the wands too with autosol and wire wool
By this time, all the parts were dry so down they all came...
and 2x everything got polished and cleaned up
The flipping rug wasn't big enough!
Onto re-assembly then! The comm on both armatures cleaned up a treat! (drop of CIF on a microfibre and rubbed did that!)
« Reply #12 on: May 16, 2020, 01:19:27 AM »
I greased the bearings as best I could too (they weren't too bad really) and re-fitted the armature to the start of the fancase
First layer on
Then the second
The coil can be dropped on now
Then generally buttoned up
Sorry, they can be buttoned up...
Front wheel now! The little axle has a sleeve that goes on either end that the wheel actually runs against. Really over engineered!
The parking slot can go back in
« Reply #13 on: May 16, 2020, 01:23:38 AM »
The two back wheels of the 4 that did not break went on
I then fired up the hot glue gun
and glued some new sealing foam under the filter cage
The filter cage squeezed the foam right down, so it formed a nice tight seal
I refitted the bumper and combined compartment seals
Popped the bag light pressure hose in
We can start filling some proper holes now! Motor seal lays down
Then the motor sits on top, making sure it sits right for the cable runs
and down it gets clamped
« Reply #14 on: May 16, 2020, 01:26:47 AM »
We can re-line the top housing with fabric goodness, all washed now!
Both post diffusers weren't actually perished, and once washed up came up like new!
All fitted!
The wiring can be run now
The PCB refitted
Tool holder clipped back in
and filled with tools!
Time for the top cover! I'd run the cable guard over the wire wheel and got it looking alot better
LED lens fitted
