Author Topic: DC24 Red Pedal  (Read 9408 times)
Offline Hutch
DC24 Red Pedal
« on: September 09, 2011, 10:20:32 pm »
Hey all,
The red pedal for tilting the DC24 has split in half and needs to replaced. Any service manual or tutorial to show how to do this?  :'(
Thanks!
Re: DC24 Red Pedal
« Reply #1 on: September 10, 2011, 03:34:13 pm »
If you look at where it pivots at either side, it is released by two screws; one of which is accessed by removing a cover held in place by three screws. After unfastening it there, it should be able to be manipulated out of the tracks it runs in near the wheels.
If you struggle, I will have a closer look at one and do a couple of photos. Shoot me back.
Offline Hutch
Re: DC24 Red Pedal
« Reply #2 on: November 19, 2011, 04:14:02 pm »
Thanks for the response DT.
I am still struggling to remove the pedal. The screws on the side with the cover is posing a problem. When you remove the cover, the screw is blocked by parts under the cover.
Could you provide some pictures to assist?
Offline Angus Black
    • Dyson Medic
Re: DC24 Red Pedal
« Reply #3 on: November 23, 2011, 11:20:22 pm »
I have a DC24 in my workshop at the moment. I will help you out with some pictures in the next couple of days.
Offline Angus Black
    • Dyson Medic
Re: DC24 Red Pedal
« Reply #4 on: November 26, 2011, 12:53:21 pm »
Remove the small cover on one side, then undo this screw.............................
Remove the cover on the other side and then undo this screw.............
Offline Angus Black
    • Dyson Medic
Re: DC24 Red Pedal
« Reply #5 on: November 26, 2011, 12:56:03 pm »
Move that switch unit out of the way, and now undo this screw......................
The pedal will now be able to be removed...................
Offline Hutch
Re: DC24 Red Pedal
« Reply #6 on: November 26, 2011, 01:43:16 pm »
Thanks Angus, much appreciated.
