Author Topic: Dyson dc25  (Read 587 times)
Offline Morephun
Dyson dc25
« on: July 05, 2020, 10:09:13 PM »
hi guys my first post here, I have a dc25 and the brush head only works for a second if I bash the end on something like a skirting board. I have used the mothers head on the vac and it works flawlessly. Anything common or anything I can check to get the head to work again cheers guys.
Online ryevac
Re: Dyson dc25
« Reply #1 on: July 05, 2020, 11:53:58 PM »
Yes, yoke cable,
Do a search in the dc25 section and more info is there for you.
or... https://manchestervacs.co.uk/DysonForum/index.php/topic,960.0.html
Offline Morephun
Re: Dyson dc25
« Reply #2 on: July 06, 2020, 12:19:42 AM »
But surely the mothers dc25 head on my dc25 vac wouldn't work and have the same symptoms? Instead her head works flawlessly on my vac. If I bang or bump the head on my vac into something the brush works for a second. I've had the head apart but can't see anything untoward..cheers
Online ryevac
Re: Dyson dc25
« Reply #3 on: July 06, 2020, 12:53:23 AM »
Sorry, didn't read your post fully,,,  >:(
Just replace the head motor in that case. Brushes probably just about worn out or sticking.
Could also be a simple bad wiring connection, but banging the head is most likely aggravating the brush contacts in the head motor. I never bothered changing brushes, or know if they are available - i always changed the motor as these are quite an old machine now.
Offline Morephun
Re: Dyson dc25
« Reply #4 on: July 07, 2020, 09:42:11 PM »
Cheers..i got a tested working one one off ebay coming in the post for 7, if anything its worth a punt.
Online ryevac
Re: Dyson dc25
« Reply #5 on: July 08, 2020, 04:39:28 PM »
Aye ok, there is a pcb in the head assembly but never had one go wrong.
Stu, Mvacs has a video in the dc25 section of how to replace the motor if you aint too sure about anything on that.
Offline Morephun
Re: Dyson dc25
« Reply #6 on: July 09, 2020, 10:03:39 PM »
Just thought I'd end the thread..the new motor works. No more banging it into things to get the head spinning
Thanks ryevac
Online ryevac
Re: Dyson dc25
« Reply #7 on: July 10, 2020, 11:38:58 AM »
 :thumbsup:
Glad to hear. normally you find the old motors vents are blocked too with carboned fluff.
