Author Topic: dc37 cycles on and off but not working  (Read 731 times)
Offline martelc
« on: September 13, 2020, 12:13:56 AM »
Hello I'm a new users and wanted some advice.  Yesterday, my dc37 stopped working.  When I press the power button, the machine turns off and on repeatedly for a split second.  Can someone give me some advice on what the problem could be?
Re: dc37 cycles on and off but not working
« Reply #1 on: September 13, 2020, 02:46:25 PM »
No direct experience with the 37, but if any other vac i would suspect main switch or motor brushes worn.
Try again but when it goes off, give the main body a slap - either of the above two issues could cause motor to restart / stop.
Also try pushing main switch and holding down, if it continues then switch could be at fault.
Difficult to diagnose through a web page.
Offline martelc
« Reply #2 on: September 14, 2020, 04:53:04 AM »
Thanks for the tip, but it is still turning on and off repeatedly.
« Reply #3 on: September 14, 2020, 04:30:51 PM »
When you say "on and off repeatedly", you mean its stopping and starting on its own? Or do you mean it tries to power up and then stops?
