Author Topic: How often do you empty your Dyson?  (Read 5851 times)
Offline lucandhar
« on: September 17, 2011, 10:18:58 PM »
I empty my DC07 every 2 weeks (as you can see from my avatar I just let it fill) and it usually lasts just over 2 full house cleans if I do the ground floor with the DC22 daily through the week then just once when I do the rest of the house with the DC07.
I empty the DC22 at least every 2-3 days using it everyday for the ground floor, even though its not full all the dirt builds up at the front passing the max line only at the front  ::)
Also has anyone else noticed the max line is getting lower and lower on newer dysons, the dc01 was huge, dc04 a bit lower, dc07 a bit lower and so on.. wierd.
Some people I know with older Dysons let it fill right up while others empty theirs after every use even if its not full. How often do you empty yours?  ;D
Re: How often do you empty your Dyson?
« Reply #1 on: September 18, 2011, 09:58:40 PM »
My wife tends to let ours fill right up till it doesn't work any more. Apparently, its my job to empty it.  :-\
Offline lucandhar
« Reply #2 on: September 21, 2011, 09:36:41 PM »
My wife has been banned from vacuuming now because she abuses the poor Dyson.. she managed to suck up 6, yes 6 of those scarf/bandana things, fills it right up and it's been dropped down the stairs on numerous occasions. It is heavy, I'll give her that one.
But still. Little does she know I secretly like vacuuming  :evilgrin0002:
« Reply #3 on: September 21, 2011, 11:04:49 PM »
She louses up ours so bad that I occasionally take it to the shop, and surreptitiously slide it within the service/reconditioning pile to jet clean it.  :-X
« Reply #4 on: June 30, 2012, 11:43:36 PM »
Do you think she might have orchestrated that situation on purpose so you do more housework?  :-X
