Author Topic: Dyson DC 07, DC 14 filter pads  (Read 432 times)
Offline grahamwin
« on: January 07, 2021, 02:48:06 PM »
Some members of this forum recommend fitting filter pads to the post motor filter, these are claimed to be easier on the Dyson vacuum cleaner motors than the HEPA filters.
 I would say that if anyone in the household as any allergy's a HEPA  filter is recommend.
The filter pads come with a coarse side and a smooth side to the material they are made from,  does anyone know which side these filters are best fitted, is coarse it side down or smooth side down ?
                                Regards   grahamwin
grahamwin
Offline Dysonboy
Re: Dyson DC 07, DC 14 filter pads
« Reply #1 on: January 10, 2021, 07:37:01 AM »
I always only pads, unless I have a specific reason to fit HEPA.
They go with the coarse material facing down toward the motorbucket , pad side facing up.
Offline grahamwin
« Reply #2 on: January 11, 2021, 11:56:58 AM »
Dysonboy - thanks for your reply re the correct fitting of filter pads. Do you also recommend a yearly change of these pads (they are cheap to buy) hoping that that this will prolong the life of the Dyson's cleaner motor ?
                                            Regards grahamwin
grahamwin
« Reply #3 on: January 11, 2021, 08:56:37 PM »
One would ordinarily last the life of the motor.
Offline grahamwin
« Reply #4 on: January 12, 2021, 01:37:26 PM »
RE Manchester Vacs last remark. I am surprised that they will last the life of the motor ? After two or three years even the HEPA ones can look very dirty. I have seen some very dirty pads and HEPA filters on Dyson's that still have the original motors fitted !
I would have thought changing them after two or three years use would be a good and beneficial thing to do.
grahamwin
