Author Topic: Dyson V7 Motorhead - Blue Light on but Motorhead not turning?  (Read 689 times)
Offline tappouni
« on: January 22, 2021, 05:44:35 PM »
Hello,
I've got a Dyson V7 Motorhead Plus - the motorised brush doesn't seem to be working. It doesn't matter if it's with or without the wand - the blue light comes on by the battery, but the motorhead doesn't power up (nor does the vacuum itself, with the head attached). With a non-motorised attachment, it works fine, with or without the wand.
Is it likely that I'll need a new motorhead, or is there anything else I should check before going ahead and buying a replacement one? Just found it a bit odd that the light remained solid blue with the motorhead attached, rather than red, despite the vacuum not powering up at all.
Thanks!
Re: Dyson V7 Motorhead - Blue Light on but Motorhead not turning?
« Reply #1 on: January 27, 2021, 11:08:42 AM »
That may not be the head, it could be a fault in the body or with the outputs somewhere.
Don't buy parts on spec. In this case, I'd suggest take or send it to a repair shop. It wants testing properly to diagnose.
